Old 06-07-2002, 07:29 PM
SVXtremist
Help please!
Hello,
My crankshaft pulley came loose and the belts came off as I was driving, and I put the belts back on. It looks like there was supposed to be a key to hold the pulley in place for timing purposes? Now that I have the belts back on, everything turns but it won't fire. Does anyone know what's wrong? Is the timing off maybe? Any help would be much appreciated. Thank you.
Allen
Old 06-07-2002, 09:06 PM
Ovidiu STAN Ovidiu STAN is offline
Check again the alignement of the timing belt. It won't fire if is misplaced.
Let us know if you need the timing marks.
Mkey?
Ovidiu
Old 06-08-2002, 11:45 AM
SVXtremist
Hey,
Thanks for your reply, but it wasn't the timing belt that came off. the two accessory belts in the front (power steering, a/c, alternator) are the ones that came off. any thoughts? Thanks again.
Allen
Old 06-08-2002, 01:35 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
I'm hoping you replaced the key? It makes a huuuge difference. Also make sure the belts didn't destroy any wiring when they came off, such as a cam sensor, etc....
Old 06-08-2002, 08:41 PM
SVXtremist
Beav
Beav, I wasn't sure if there was supposed to be a key. Is there? Because there is a little groove in the pulley, but I didn't see one when I put the belts back on. Thanks.
Allen
Old 06-08-2002, 08:46 PM
Beav's Avatar
Not as old as Randy
Without the key the t-belt sprocket will spin on the crank snout. Be sure to check all keyways (grooves) for damage before inserting a key, otherwise your new key won't last long.
