Old 06-06-2002, 07:39 PM
casper150
wheel size?!
ok i was reading a post a while ago, and just trusted the guy knew what he was talking about, but now i am wondering...the svx wheel offset is what?? he said offset is 50? now i see the guys with the ones on ebays said they are 40. which is it?!
Old 06-06-2002, 08:02 PM
Never2phat Never2phat is offline
to my knowledge
Factory rims.............
Bolt pattern: 5x114.3mm (4.5")
Centerbore: 56mm
Offset: 50+
You can go with a lower offset, as others have done, but you up the chances of bearing problems. Some members have as low as a 38+ offset and have had no problems.
B.C.
Old 06-06-2002, 09:21 PM
wawazat??'s Avatar
Yeah, I'm still around
According to the SVX service manual
offset is 55mm on the stock wheels as I have stated in previous posts. I have 17" x 7.5" with 48mm offset on mine.
Down to none
Old 06-07-2002, 03:34 PM
Lowered SVX
why is everyone so worried about offset.....
guys for more than a year i have been running 38mm offset enkei RS6's with no problems. they 17 x 7.5in. with 225/45 Potenzas plus my car is lowered two inches. i have had no rubbing or any other kind of problems.
"Too much fun to drive!"
Old 06-09-2002, 07:24 AM
casper150
what do you guys think about 16" with a 40 offset?
Old 06-09-2002, 09:52 PM
squiggy
wheel info needed
how about a wheel that is 16 X 7
5 x 114.3 (5 bolt pattern 114.3 spacing)
42 offset..
what is the widest tire I can use that will fit both the rim and not rub the well??
what about the 42 offset?? how will that affect my car??
thanx 4 da info---squiggy
Old 06-13-2002, 12:01 AM
Motorsport-SVX's Avatar
Motorsport-SVX Motorsport-SVX is offline
check out www.planetsvx.com
no truth to it
Theres NO truth to the rumor of lesser offset rims causing premature wheelbearing problems !!! Svxs with stock rims STILL have the same amt of problems as those with different offset rims. .IMHO the very positive offset Subaru uses might be one of the reasons Causing the bearing problems. I can see how it would put more load on the bearings too. For the record, I truley believe you can use anywhere from a +38 - +50mm offset rim and experience no issues.
My mom will forever live in me and
never be forgotten, one day Ill see her again
CLICK the LINK below to Visit the SVX Store:
http://www.planetsvx.com
http://www.motorsportwarehouse.com/svx/sig2.jpg
Cars in the garage:
92 Toyota Soarer Single Turbo JDM RHD
70 Boss 302 Mustang 39k original miles
97 SVX Lsi
92 Liquid Silver Murano-ized (1st of its kind)
71 Cougar Xr7 Conv 351c 4v 4spd
69 SS Camaro 350
71 Nissan RHD Fairlady Z
70 Stang Fastback
70 Amc AMX 390
71 240z
89 Conquest TSi w/ 5.0 v8 swap
84 Mustang GT Turbo conv
"good, if it bleeds, we can kill it ....."
Old 06-13-2002, 10:36 AM
wasions's Avatar
wasions wasions is offline
SVX Black Belt Master
I was checking on that a year or so ago and found that the biggest problem with 16" aftermarket wheels, is that there's very little clearance (like measure in thousanths of an inch) between the rim and the caliper. Looks like a pretty small pebble could do some serious damage.
. . . or maybe not, I didn't get them.
Steve
'95 Polo Green SVX L AWD, 188K - "Kermit" (Gone, but not forgotten)
'02 Outback LLBean, 56K
'02 Black Sapphire Volvo V40, 133K - "Shadowfax"
'06 Triumph Tiger, 19K
'99 Suzuki DR350SE, 8.5K - "Geezer Killer"
Old 06-13-2002, 12:17 PM
no....
thats the least of your worries honestly. If a caliper is that weak it shouldnt be on the car. The pebble would be dust in a second...
Put on what you like with any of the offsets mentioned before...youll be fine. Ive had every size and combination on my own SVXs for the last 3 yrs....Ive been selling custom rims-tires since the mid 80s......my advice comes from a proffesional standpoint.
Cars in the garage:
97 SVX Lsi
69 SS Camaro 350
70 Stang Fastback
70 Amc AMX 390
71 240z
Old 06-13-2002, 05:59 PM
casper150
well, thanks for everyones thoughts i will let you know how they look or work by next week, that is if the $115 power steering lines comes in by then!
Old 06-13-2002, 07:59 PM
Re: no truth to it
Hi Dayle, I don't think 12mm would affect the bearings.
Don't confuse the wheel dish offset with the steering axis offset.
The steering axis is a line drawn, looking from the front, down from the top strut bearing, through the bottom ball joint, touching the ground in the center of the tyre tread. This is zero axis offset.
If less wheel dish offset is used, say 38mm instead of 50mm, that would place the tyre tread center 12mm inside the steering axis center to give a negative offset or "negative scrub radius".
This positive or negative scrub radius is used by designers to counter act other problems. It won't give any problems while both wheels have the same grip on good roads.
If braking hard on a uneven road the wheel with the most grip will try to steer in to the opposite side, causing the car to dive around under brakes. When accelerating around a corner, the outside wheel would have the grip to steer the car away from the cornering line, to produce "torque steer".
If you want the car to steer well under all conditions, use the same wheel dish offset.
Old 06-13-2002, 09:45 PM
Re: Re: no truth to it
All good info, but getting back to the bearings, how far in or out the wheel sits from the bearing center would determine how much load is put on the bearing over an extended period of time and miles.....Im just curious as to how much it really effects these cars in stock configuration.
Cars in the garage:
97 SVX Lsi
69 SS Camaro 350
70 Stang Fastback
70 Amc AMX 390
71 240z
Old 06-15-2002, 05:20 PM
Re: Re: Re: no truth to it
Don't know Dayle, don't think 12mm (.5in) would cause that much more lateral load on the bearings. Wheel offsets that I have seen on older "hot rods" where the wheel center has been reversed to give 2"to 3" offsets, certainly did.
I think Subaru missed the boat, in the wheel bearing dept. I
don't think they accounted for the high lateral forces, that this car can generate at speed in corners.
The bearing tracks are too close together, to handle these high forces. If the bearing tracks were, say 50mm (2") apart, the lateral forces would place less load on the races.
So what is the out come, don't corner fast !!!!!.
This car sticks like s**t to a blanket and I don't mind paying for the thrill
Harvey
Old 06-17-2002, 10:49 AM
Lowered SVX
Finally.....
Dayle maybe your opinion will finally end this stupid offset myth. I have been hearing people terrified of putting 38mm offset wheels for the last year. I tried and tried to tell them that everything would be ok as long as the stayed in the 7.5in or lower range.
Hopefully now this myth will be put to rest.
