Old 06-05-2002, 10:25 PM
double0bondo
knock sensor??
does anyone know what is involved in changing the number 2 knock sensor, mine is bad, and have not even lookd for it yet....is it a bad job??
Old 06-05-2002, 11:00 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
All you need to do is use the search box...
http://www.subaru-svx.net/forum/show...&threadid=1804
Old 06-05-2002, 11:09 PM
double0bondo
k
sorry
Old 06-05-2002, 11:14 PM
Beav's Avatar
Not as old as Randy
No problemo!
double0bondo
bty
i checked out the thread, can i get clarification on which side is the #2 sensor????
Old 06-05-2002, 11:17 PM
Beav's Avatar
Not as old as Randy
It makes no differnece really, both should be changed at the same time. Where are you getting a reference to #2 sensor?
Old 06-05-2002, 11:20 PM
Beav's Avatar
Not as old as Randy
While I'm thinking of it, most times when a scanner, etc. refers to #1 and #2 you need to see which bank of cylinders is the leading bank - in other words which bank is #1 spark plug on? It would be sensor #1 and the opposite bank would be ....drum roll please....sensor #2.
Old 06-05-2002, 11:24 PM
double0bondo
subby dealer
suby dealer said one o2 sensor was bad, but both should be replaced, in pairs, but they said the # 2 was bad, and they do not need to be replaced in pairs, they stated that, unlike o2, which should always be replaced in pairs, a knock sensor, can be done indvidually... because, they work with a "one trace" resistence factor, where as the o2, are different...i didnt know what to say when they said that...except...um, ok thanks!! lol
Old 06-05-2002, 11:47 PM
Beav's Avatar
Not as old as Randy
Personally I agree with replacing both O2 sensors at the same time and I could live with one knock sensor at a time - but not for the reasons they gave you. With the O2 sensors it's more of an age/balance thing. O2 sensors are like us, the older they get the less active they are. Each forward sensor controls its respective bank of injectors, so when it gets old and sluggish its bank of injectors isn't operating at the same peak efficiency as the bank with the new O2 sensor.
Knock sensors, on the other hand, operate like the push-button ignitor on a gas grill. A little pressure or vibration and they generate a small voltage that's sent to the computer. They operate in a go/no-go world, either they work or they don't. However when one bites the dust the other probably will soon follow suit. My recommendation to replace both was based on the factory manual that states that they should be replaced in pairs.
Old 06-06-2002, 12:06 AM
To Beav
Beav, I love the post scripts appending your signature, they often light up my day. Where do you get them from? If they are original you are aven brighter than I thought!
Keep it up, Trevor.
Old 06-06-2002, 12:22 AM
Beav's Avatar
Not as old as Randy
I've a rather large family and I pluck favorites from their e-mails, etc. I only wish I had the time to dream up some of my own, or at least some that are postworthy...
Old 06-06-2002, 12:57 AM
Beav, even though they are not original you go to the trouble of selecting them and posting them and for this you have my thanks and I am sure many others. Special good wishes, Trevor.
Old 06-19-2002, 08:00 PM
Roger8519 Roger8519 is offline
knock sensor
i just had mine replaced 2 days ago. cost me $165. the part is only 70 though
Old 12-03-2002, 08:01 PM
CaptHowdMasta
my god
my CHECK ENGINE light came on a few days ago and they told me it was my Knock sensors so they replaced both costing me a little over a 100 for both sensors and 180!!(3 hours) FOR LABOR totaling nearly 300 dollars. how long do you think it really would take to diagnose the problem and change both knock sensors?
Old 12-03-2002, 08:27 PM
Beav's Avatar
Not as old as Randy
From the book:
Knock Sensor
. Replace . .
. . MPFI .
Warr. Std.
1.9 2.7
Notes
. . . Includes: Troubleshoot And Replace Each Component.
Since I doubt it was a warranty repair, multiply the shop rate by 2.7 hours and toss in the price of the sensors.
However, if you really want to press the issue, there was a TSB issued with revised procedures and labor times as such:
Subaru TSB 11-46-95
Applicability: 1992-1995 SVX 3.3L
FAILURE CODE OPERATION # LABOR DESCRIPTION LABOR TIME
KNOCK SENSOR A145-581 KNOCK SENSOR BOTH-REPLACE 0.7
UEA-48 (INCLUDES ACCESSING DTC
USING SELECT MONITOR)
Note :Refer to revised 1992-1995 SVX 3.3L knock sensor replacement information on the reverse side.
This shows replacing both sensors in .7 hour. Might be worth pursuing. Good Luck!
