Old 06-25-2007, 05:45 PM
kwren's Avatar
kwren kwren is offline
information on oil pump maintenance for motor?
replace seal and what else any input appreciated!
Also where is accesss to the pump?
Thanks,
Keith
Old 06-25-2007, 06:58 PM
immortal_suby's Avatar
Thread Killah
replace the front main seal is all that is necessary.
access is behind the front main crank pulley - you have to pull the timing belt to get to it.
Locker Link
2015 BRZ Limited 6MT
Old 06-25-2007, 07:03 PM
kwren's Avatar
Thanks for the information!
I appreciate it!
Take care,
Keith
Old 06-25-2007, 08:10 PM
budbaer's Avatar
budbaer budbaer is offline
Send a message via AIM to budbaer Send a message via Yahoo to budbaer
You should think about replacing the timing belt as long as you are already in there. Water pump isn't too expensive either, you could do it right and replace everything while you have it all pulled apart.
Old 06-27-2007, 11:45 PM
kwren's Avatar
Thanks for the advice!
I replaced the water pump a few thousand miles back but now have an idler bearing problem. I ordered the roller belt kit for 209$ from ebay and am doing that all now. Am celebrating my 77th birthday today, so if you read this thread say happy birthday, Keith! I thank you in advance!
I appreciate all the help!
Keith
Old 06-28-2007, 08:07 AM
cdigerlando cdigerlando is offline
Front End Job
I just did my timing belt (power enterprises) in the WRX after noticing a small seal leak in my radiator (95k miles). While I had everything apart I replaced all my idler pullies, radiator (koyo aluminum), tensioner pully, water pump, thermostat (160 deg), timing belt, oil pump (cosworth), cam seals, crank pully, alternator pully, power steering pully (unorthadox aluminum on all), and crank seal (the seal being referred to in the previous post). While I had everything apart it is simple to just get it all done at once. Since you already did your water pump, there is no need to do that, but you might consider replacing all of your idler pullies. I'm going to when I finish by build.
Chuck D.
1992 Subaru SVX LS-L - Heavily modded turbo
2002 Subaru Impreza WRX- Turboxs stg3 & Susp. Mods
Old 06-28-2007, 09:52 AM
budbaer's Avatar
Happy Birthday Keith!
Old 06-28-2007, 10:07 AM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
Ditto, Happy Birthday
1995 Subaru Svx L / AWD
Old 06-28-2007, 04:47 PM
HumpSVX's Avatar
HumpSVX HumpSVX is offline
Send a message via AIM to HumpSVX
Happy Birthday and many more!
-Hump
'99 RBP Subaru Impreza 2.5RS
'92 Pearl White Subaru SVX - 136k - My first SVX -traded
'92 Yellow Subaru SVX LS "Bert" - 123k -The first SVX Convertible
'92 Orange Subaru SVX LS-L "Ernie" - 139k -The first SVVVVVVX (stretched SVX limousine)
Okay, so the bottom two cars don't actually exist but what if?????
Old 06-28-2007, 06:19 PM
shotking's Avatar
shotking shotking is offline
Happy b-day!
Joshua
92 Ls-L pearlie 73,000 miles
Old 06-28-2007, 07:49 PM
kwren's Avatar
You found your car!
Originally Posted by shotking
Happy b-day!
Next time take your hunting dog with you! he can always find your car!!
Kidding of course!!
Thanks for the happy birthday to all who responded
It was a great one!
Old 06-28-2007, 07:54 PM
kwren's Avatar
Originally Posted by cdigerlando
I just did my timing belt (power enterprises) in the WRX after noticing a small seal leak in my radiator (95k miles). While I had everything apart I replaced all my idler pullies, radiator (koyo aluminum), tensioner pully, water pump, thermostat (160 deg), timing belt, oil pump (cosworth), cam seals, crank pully, alternator pully, power steering pully (unorthadox aluminum on all), and crank seal (the seal being referred to in the previous post). While I had everything apart it is simple to just get it all done at once. Since you already did your water pump, there is no need to do that, but you might consider replacing all of your idler pullies I'm going to when I finish by build.
I bought the kit with all the pulleys in it from EBay.
The timing belt was American made! Keep your fingers crossed! A Japanese car with an American belt! what a world!!
Old 06-28-2007, 10:18 PM
svxaddict svxaddict is offline
Kieth
HAPPY BIRTHDAY hope god gave you many more years to come.
Old 06-29-2007, 09:59 AM
wawazat??'s Avatar
Yeah, I'm still around
Don't forget the O-ring behind the pump as well.
Todd
Down to none
Old 06-30-2007, 05:00 PM
kwren's Avatar
thank you!
i appreciate your kind words!
