Old 06-08-2007, 12:48 PM
RedHotSVX RedHotSVX is offline
gettin there....
Send a message via AIM to RedHotSVX Send a message via MSN to RedHotSVX Send a message via Yahoo to RedHotSVX
IACV Code....
Hello everyone....Has anyone had any luck with a removing,and cleaning the throttle chamber/IACV for a P0505 code? Or will I need to buck up and replace.I haven't gotten into it yet,the idle doesn't do anything wierd,the light just cam on,so I cleared it for now.
Just thought I'd inquire...Thanks
Mike....
8/96......Vin 100109
1997 LSI,18 inch Axis wheel(summer),16 inch ALT wheels(winter),Trans temp/Volt gauges,Iridium plug's, Autotechnica intake,silverstar high/low and fogs,polyurethane sway bar bushing's front and rear,Smallcar shift kit,Stebro exhaust finally..SWEET!!
Motorsports drilled/slotted rotor's front and rear with ceramic pads and SS brake lines.
1997 SUS Legacy,finally got the engine in after a year!!
www.myspace.com/devilhornz
Old 06-13-2007, 07:01 PM
Did you resolve the code yet? I doubt cleaning will resolve it although it wouldn't hurt. Ensure the connector never worked itself loose.
