Old 06-08-2007, 05:33 AM
thermostat replacement
Is there a specific way to remove the thermostat without completely destroying the rubber gasket?
Old 06-08-2007, 05:46 AM
JaySVX's Avatar
JaySVX JaySVX is offline
No. If you buy a new thermostat get a new gasket, chances are you'll be scraping the old one off with a flat-head screwdriver anways. Make sure you clean the surfaces of both sides as best you can before applying the new gasket.
If you are having difficulty finding a gasket, you can purchase a type of gasket that is a sheet, you place it on and it marks the sheet, then you cut it out with an exacto-knife to create your own gasket. I've had to use these in the past, and generally i have no complaints, they cut easy enough. I wouldn't use it for something like the heads, intake, or exhaust though, only because it's near impossible to cut them with that sort of precission, but for cooling i would say it's fine.
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 06-08-2007, 04:04 PM
I would agree. Get a new gasket along with the new thermostat.
Old 06-13-2007, 07:08 PM
The last thermostat I ordered came with the gasket.
