TCU checks
OK Guys, what am I doing thats dumb........
I've tried to follow the check TCU guide on here, and heres the rub..... I have a japanese import into NZ (92), so when I try to turn the ignition on with the car in "D"....... nothing happens. My car will only start in either "P" or "N"...... HELP!!!!!!! the flashy green power light is driving me mad! ALex |
You don't have to start the engine. You just turn the key to the on position so that the dash lights come on.
Subaru ECU and TCU Website 1992 Alcyone SVX Version L 1992 Alcyone SVX Version L 1994 Alcyone SVX S40-II 2004 Subaru Legacy 2.5 SE Sports Tourer 1996 Subaru Legacy 2.2 GX Wagon 1988 Subaru Justy J12 SL-II |
There is no need to actually start the engine to run the test. You only need to turn on the ignition, i.e. the dash lights. Don't engage the starter. In fact It would not be possible to do the test with the engine running, you have to shift the lever from range to range, and switch on and off the manual [MANU on the dash] button I think, if I remember correctly. Detail is on the How-To Here The second one at the bottom is the detail for TCU codes. There are two methods, one for existing codes, one for old codes. Note at the top, it starts with ignition OFF. Try again without starting her up Joe
Cheers guys, so what about the "press throtle to cut idle switch" bit?
This causes the end of diagnostic routine, and your power light will then blink out the codes. It will repeat one code over and over if there is only one. Otherwise it will blink them out one after the other.[and repeat] Joe
Thanks Joe,
Not too good with techie things....lol can chop up bodies and put them back together, but follow instructions on a sheet...... might as well ask me to swim to the moon |
My black SVX looks cadaverous at the moment. Electrical entrails all hanging out under the dash.
You can only learn by practice and asking questions. Let us know what code you get. Joe
Thread Tools | |
Display Modes | |
