Old 01-31-2007, 09:21 PM
crotchrocketony's Avatar
crotchrocketony crotchrocketony is offline
trans fluid in my diff
I just want to make sure before I pull my trans, if im getting trans fluid in my front diff, its the tube thing that goes from the trans and the front diff that would be leaking right? I put a new diff on my trans and had this problem the next day. I was going to just park the car and let it rott in the weeds.. but she only has 80k with nothing else wrong with it....the trans only has 30k and the car is clean!(but it spends more time broken then right!) but Im figuring Ill fix it...its a $22 part that is causing all my problems!!(this time) this is the part number i found " 31295AA003 Seal Pipe "
Tony
1992 SVX black/redish 62k awd, rims, brakes..and a few add ons for extra HPs
Old 01-31-2007, 09:31 PM
Tony
Or the pinion seal, was it renewed.
Old 01-31-2007, 09:37 PM
i understand if the diff fluid was leaking into the trans its the pinion seal and if the trans fluid is leaking into the diff its the sealing tube.......
Old 02-01-2007, 11:00 PM
tmak26b tmak26b is offline
Just make sure you use 75w90 gear oil in your diff, not ATF fluids
