Old 10-22-2006, 11:30 AM
svxthc's Avatar
svxthc svxthc is offline
These Rotors Bradis Any Good?
http://cgi.ebay.com/ebaymotors/Subar...spagenameZWD1V
I'm about to order them. Front Bradis, Cross Drilled. Will they warp faster than stock? Good price at 135? What else would you recommend...? Are raceconcepts.net svx rotors bradis also? Should I just go with slotted as there is more surface area from race?
1993 SVX Anniversary Edition #64
Old 10-22-2006, 05:09 PM
shotgunslade's Avatar
If you are buying them for looks, cross-drilled are OK. If you use them really hard, such as for track days or AutoX, drilled rotors can crack. Would recommend going with slotted only for those uses.
Old 10-24-2006, 09:11 PM
immortal_suby's Avatar
Thread Killah
I've had slotted bradis on mine for about 4 years now with great results.
I wouldn't get drilled though.
Locker Link
2015 BRZ Limited 6MT
