Old 10-05-2006, 02:21 AM
Weird Rpm problem
Ok, sometimes I start my car and the rpms go to 1500 and drop to 750 and sit there like normal. Other times I will start my car and the rpms go to 1500 and then drop to like 50-100 and it feels like the cars about to die, but never does. About two weeks ago I cleaned my MAF with MAF cleaner and it seemed like it helped a little. Any ideas? This a problem other people have had? I would just like to get it fixed for good. Thanks.
Old 10-05-2006, 04:28 PM
Manarius's Avatar
Manarius Manarius is offline
Clean the throttle position sensor? Check to see if all the vacuum tubes are in their correct places.
MAF may be toasted - having any driving issues or just idle issues?
-Jason
-Obi Wan Kenobi
Old 10-05-2006, 04:49 PM
Idle problems.
Sounds like the Idle Air Control valve is sticking. It is trying to move to set the idle speed, but is probable goo-ed up, and sticking. Its located under the throttle bodies. You may be able to spray some carb cleaner into it, but it would be better to remove it and give it a good clean.
Old 10-07-2006, 06:27 PM
No driving issues so far just idle. It only acts up once in awhile for like the first 5 seconds after I start my car. Yeah I might just have to try cleaning a few things. Thanks for your responses.
