Old 10-02-2006, 09:37 PM
The Molinator
Great TIRES...
If you're looking for new tires....OR having trouble with your current tire choice..you should seriously consider the Bridgestone manufactured AVON tires that America's Tire Company just suggested when my Yokohama ES100's wore out prematurely in the rear (a problem with my drop spring/Koni strut insert mod)! They were so good (I HAD NO IDEA HOW MUCH NOISE THE YOKIES WERE PUTTING OUT!)...I went back...ordered 2 more for the front (SELLING BACK TO AMERICA'S TIRE CO. 3 MO OLD ES 100's)! My car has never been quieter!...AND seems to handle good! Also, the steering is smoother...less shaking (the ES100's evidently weren't able to balance..after two balancings..???) also. I run 245 45 16's. I'll get the model # if needed or desired...
Jim
P.S. They list at $98....They charged me $65 each both times on a special deal..(?) [The ES100's cost $122 each!]
P.P.S. The ES100's were so "rough" that I thought the engine was running at high speeds...80 to 120 mph! Now...SMOOTH!
Jim
Old 10-03-2006, 08:13 AM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Useful info; Sometimes wheels can't be balanced correctly if you use a flatfix in your tire. Glad those tires work out for you, I'm also tired of hearing tire noise from my Yokohamas. I'll check out those tires, thanks.
Old 10-03-2006, 09:39 AM
ShiuludeSVX's Avatar
Tire Noise
I've been running Kelley 225 / 50's, and my Mechanic says what he hears is the tires.
They are wearing down from time, so detail the item, and I'll give them a try when it comes around.
Old 10-04-2006, 01:30 AM
The Molinator
Details....
Avon Tech M500 245 45 ZR 16 94W I love 'em....Today I went 105 mph for a short stretch on the way to work. They were smooth and quiet! I believe their list is $98....but as I said..they (America's Tire) gave them to me for $65 each! I like them more...each time I drive on them!
Check 'em out, Bro's! Jim
Jim
Old 10-10-2006, 01:39 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
James,
Please post back up after you've got a couple of thousand miles on the tires. The reviews on TireRack indicate that they don't last past 10k miles
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 10-10-2006, 02:12 PM
The Molinator
AVON tires
OOOOPS!
I will let you know! ...YIKES...??? I DO LIKE THEM THO!
Jim
P.S. My mechanic (Porsche) has them on his Audi...and likes them. He did say they don't wear as long...BUT he didn't say 10K! My first Hankooks (102?) wore out in 13K!
Jim
