Old 09-28-2006, 11:02 PM
hexadec0079's Avatar
hexadec0079 hexadec0079 is offline
Parts Breaker, Tire Waster
Send a message via AIM to hexadec0079
4.44 Need Advice
I have a tranny, rear end and lots of help (thanks GreenMarine, lol) what else do I need to do the swap. Can I use stock shifter mechanism (lever). Also is the brake switch integrated with thrans, cuz mine is stuck. Thanks for the help
1992 SVX- -Drivetrain by BUDFREAK-
Green, LS with spoiler, 157,000, ES Swaybar bushings, 9005/6 mod, 2.25' Dual Exhaust, Custom Grounding, Hyperwhite fogs, LED tails, 4.44s, custom Blitz intake, tranny cooler, thats about it, for now...
1997 Chevy 1500 -FOR SALE-
5.7 liter, Z71, 300hp+, still almost 20mpg
1986 Merkur XR4Ti -SOLD-
SVO Engine, T3 hybrid turbo, K&N, custom ducting, Initial D painted, 18psi, fastest car for under $1000, ever.
Old 09-29-2006, 12:16 AM
The swap is VERY straight foward minus swapping the rear diff. You use all the same parts as the stock tranny. Your parking brake issue is something unrelated
Old 09-29-2006, 12:31 AM
not the parking brake. The switch to shift when pressing the brake pedal
Old 09-29-2006, 12:33 AM
on a side note, i found some rims on ebay, stock R32 sized 16x6.5 5x114.3 +40 those should fit, right?
Old 09-29-2006, 09:15 AM
elninoalex's Avatar
elninoalex elninoalex is offline
Registered Abuser
Those should fit, but they'd be an inch narrower than the stock wheels.
Old 09-29-2006, 10:52 AM
And stick out 15mm farther per wheel and be harder than your wheel bearings.
Old 09-29-2006, 11:32 AM
ok, 86 those wheels, but thanks for the responses
but what about my original problem with the trans lock?
Old 09-29-2006, 12:01 PM
Correction, because the offset is about .5" further out and the rim is 1" narrower (.5" on each side) These rims will stick out the same amount as stock.
Old 09-29-2006, 12:15 PM
And the INSIDE of the wheel will be out about 1" farther.
So it will still be harder on the wheel bearings.
But you still got me.
Old 09-29-2006, 12:23 PM
ok, children ,back on topic to the trans lock
Old 09-29-2006, 12:46 PM
OK, so when you have the key on, and push the brake pedal, do you hear a click at your shifter?
You should.
And you should be able to feel the solenoid movement through the shifter.
btw, do your brake lights work?
Old 09-29-2006, 08:58 PM
sounds like your shift lock computer is borked... they go out all the time, any suby shift lock "should" work but try to find one on the network, they are easy to come by from 5mt swaps
