Old 09-16-2006, 10:18 AM
drivfour drivfour is offline
severe vibration-need help
I finally installed the 1996 legacy 4eat with converted #2 speed sensor, converted rear(put 96 rear gear on original limited slip gear set). the speedometer reads correctly and I do not have error codes.
The transmission does not seem to perform right. I am trying to figure out what is not working exactly but here is what I have founfd so far
Terrible vibration at 35-40 mph especially when power is applied- not coasting
shifting from D to 3, there is no difference- seems like overdrive is not engaged
I seem to remember car would free wheel if power was off- does not feel the same
on a slight hill car does not roll back ward at idle
I am looking for help in isolating these issues- I do not want to give up on the automatic
Thanks for help
Old 09-17-2006, 04:26 PM
I tested today and found out that the vibration- very loud drumming, is right at 42 mph- louder with slight power on quiter if neutral pwer- does not mater in 3rd OD or neutral. Nor other speeds up to 70 mph had a peak in vibration. Any thoughts???
Old 09-18-2006, 01:39 PM
How are all the joints on the driveshaft?
Old 09-18-2006, 11:13 PM
They were stiff but moveable. What level of movement typically causes vibration-for example the joint falls down under it's own weight etc?
Also, if drive shaft and flanges were marked for orientation, how were they marked from factory?
Thanks
Old 09-24-2006, 11:42 PM
drive vibration problem solved
I changed three things
put in fourth drive flange bolt that I forgot to install
put pb then oil in the slightly stiff u joint
matched paint marks on driveshaft and rear flange
vibration at 43 mph gone- quiet and smooth thruout.
Not sure which of the above fixed problem but it is a dramatic improvement.
