Old 09-03-2006, 03:51 PM
Cho Cho is offline
Send a message via MSN to Cho
Unhappy Transmission Failure
Right now im kinda stuck with having to rebuild the transmission because I'm only 19 and I don't have as much knowledge as you guys do about this 4EAT trans. Maybe you guys can give me some insight on what to try first before I take it in.
The Problem:
The transmission simply wont catch the first, second, and reverse gears.
I can still drive it on D, but its very slow on the 1st and 2nd gears until it hits 3rd and drives fine the rest of the way until I slow down. Then it does it all over again.
I had a technician take a look at it before when this happened once and he adjusted the line pressure and cleaned a solenoid then the car started to shift through all the gears again.
Worked for about a month then just a few days ago it failed on me again. When I took it back to him to check it again, he could not get the gears to work again and said its most likely an internal problem and will need a rebuild.
I called around and got quotes on a rebuild and it would cost me about 2300.
Cho
1995 SVX L - Emerald Green
1992 Supra Turbo Red
Mods: Slotted Front and Rear Rotors, K&N Stock filter, Blue LED Interior Lights, and New Paint.
Old 09-03-2006, 04:04 PM
dwd1985 dwd1985 is offline
Sounds to me like your low-clutch is gone. Do some searching around this site, and look into a 5 or 6 speed swap, or a 4.44 geared or 4.11 geared swap. They are better options then a stock 3.54 SVX tranny.
Old 09-03-2006, 04:58 PM
Cho Cho is offline
You know, I would love a 5 or 6 speed trans. I just cant afford it here in Alaska. To do it here, it cost 6000+. Thats just too much for me. For that money I would rather invest into my dream project which is a 240sx drift car. Unless one of you guys wanna fly up here and help me do it.
dwd1985, thanks for letting me know a possible problem with the trans. I thought the same thing too.
Cho
Old 09-04-2006, 11:27 AM
Good luck with the project. $2300 sounds about right for a rebuilt one.
Old 09-05-2006, 11:25 AM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
Cho,
I just spent a little over $2K with tax for a rebuild so you're in the ballpark. Make sure there is a written warranty.
Gene
Gene and Ben
Old 09-06-2006, 04:56 PM
Cho Cho is offline
Originally Posted by bwb3
Cho,
Gene
Thanks, ill keep that in mind. this time around though, im going to install a 25,000 GVW Tranny cooler. So when the time comes for me to do the 5mt swap, Ill still have a good trans to sell off.
Cho
