Old 08-29-2006, 11:58 PM
Yoda3000's Avatar
Yoda3000 Yoda3000 is offline
(This account is in rememberance of)Duct Tape Man
Send a message via AIM to Yoda3000
Alignment Questions
So here's the deal. Over a year ago I replaced my front strut/spring asseblies with the ones off my parts car and I didn't matchmark the camber bolts or adjust them or anything. Then I replaced a rear wheel hub, again not paying attention to the camber.
Strangely when I'm on the highway my stearing wheel is tilted to the Left 10 degrees or so, but the car keeps going straight when I let go of the wheel.
I just got new tires and I want them to wear evenly and last a long time. Should I get an alignment done? My even bigger question is can/should I do the camber myself and if so how?
Midas wants to charge me $50 for the alignment plus $44 per side that needs the camber ajusted.
So what should I do?
Early deceased SVXWN Member
July 1986 -- February 2007
Michael - Duct Tape Man
1992 Burgundy SVX LS-L, 138K: Brembo Slotted/Drilled Rotors, B&M Tranny Cooler and Filter, SmallCar Shift Kit
1992 Burgundy SVX LS-L, 123K: DEAD FROM FATAL HAIL DAMAGE, Parting out so PM me if you need something.
"It's only after we've lost everything that we're free to do anything" - Fight Club
"This is not my life, this is not my home, this is not me. I HATE THIS!" - Static X
Old 08-30-2006, 05:59 AM
dcarrb dcarrb is offline
Pay to have the car properly aligned.
dcb
Old 08-30-2006, 07:16 AM
Speedklix's Avatar
Locker Link Solution
Just pay to have it done, but I wouldn't do midas. Go to a dedicated alignment shop and just pay the 65-100 bucks to have it done all around.
You can do it yourself, but you need to have some carpentry ability and an engineer's mind. For $30-40 you could buy/build what you need to do an alignment equal or greater to anything a franchise mechanic could do on a rack... But you need to do it now and how often are your really gonna need to perform an alignment? So just pay. Takes less time and you don't have to do anything but drop off the car and open your wallet.
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 08-31-2006, 04:58 AM
BAC5.2 BAC5.2 is offline
Basic alignments run around $96 bucks at our shop.
Full custom alignments are $120
It all depends on what we are doing and what the setup on the car is.
I've done the string-and-paper method. It works for a good general alignment, but what a pain in the ass. Everytime you want to make a slight change, you need to jack the car up and crawl underneath to try and fix it.
I did my own alignment with string and then tossed the car onto the alignment rack, and it turned out to read the specs I came up with on the floor.
Phil
