Old 07-17-2006, 10:43 AM
SVXplorer SVXplorer is offline
Send a message via MSN to SVXplorer
ECU Bead Crush Question
I'm finally trying to pull my ECU today to do the 'bead crush' (I was away for a bit), and I'm having a really hard time loosening the nuts on the bracket, just because it is so tight in there. I've tried both a ratchet and a crescent wrench, but because they're both really short, I'm having trouble getting some decent leverage. What tools have other people had the most success with? Suggestions, please!
1992 LS-L Touring, Ebony Mica, 177k kms. Bead crush complete! Needs some bodywork & interior bits. Gold OE-style rims , Sony deck . For sale or trade
1992 LS-L Touring, Liquid Silver, 106k mi. "Alice." Brand-rebuilt title. Mods: WRX 6-CD changer, 16" Rage Vigor, PWR rad, Perrin LCP, JDM v.8 6MT.
Old 07-17-2006, 10:47 AM
Different lenghts of a 10mm wrench, patience and a chiropractor.
Old 07-17-2006, 11:20 AM
SubaSteevo's Avatar
No longer blue member
Skinny fingers come in handy too
-Steve
01' MSM Lexus IS300
Old 07-17-2006, 11:26 AM
Speedklix's Avatar
Locker Link Solution
you only need to remove the bottom two. just lossen the top one and it will slide up and off the bracket.
I probably used a wrench but may have been a gear ratchet. Tight places are why I bought it.
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 07-17-2006, 03:00 PM
1 long 10mm wrench was all I used.
Old 07-17-2006, 10:06 PM
Finally done!!!!
Thanks for the advice. All it took was a 10mm wrench, a bit of blood, and a vast vocabulary of naughty words, but I finally got the sucker out. The one nut closest to the passenger side was a b!tch. But now I have the two halves of the ferrite bead sitting on the bookcase in the livingroom, stuck to a piece of electrical tape.
And, best of all, my car didn't bog on the test drive. Hopefully, this has solved the problem for good. Now, just to get the cracked rad fixed...
Old 07-18-2006, 10:12 AM
Be aware that you have also reset the ECU by disconnecting it. Give it some time to relearn and you may notice a bit of bog return.
I noticed, back when I still had the 4EAT, that the car would be more peppy right after I reset the ECU.
Old 10-13-2007, 12:54 AM
sd2649's Avatar
sd2649 sd2649 is offline
Driving in Style
what is the bead crush supposed to do? sorry to be a noob, but I couldn't find out using the search.
-Steven
1992 SVX Purple and Black 5 speed swap
SOLD
*1993 SVX Silver and Black
*1994 SVX L Barcelona Red FWD
Old 10-13-2007, 09:27 AM
LetItSnow's Avatar
Still Cant' Say the Z-Word
<linky> for you!
Old 10-15-2007, 01:58 PM
sd2649's Avatar
Driving in Style
thanks, guessing it's worth nothing to my 1994 model.
-Steven
SOLD
