Old 07-16-2006, 04:22 AM
Blackbir2001
Want to run cable from radio to CD player
Where should I run the cable - down the prop shaft tunnel or under the trim beneath the door? Any things I need to be careful about?
Old 07-16-2006, 07:27 AM
immortal_suby's Avatar
Thread Killah
I would just tuck it under the center console piece and then under the back seat. that's how I wired my amp and subs and you can't see the wire.
Locker Link
2015 BRZ Limited 6MT
Old 07-16-2006, 12:52 PM
I would do it the same way. Under the carpet.
Old 07-17-2006, 07:29 AM
Blackbir2001
Update.
Gents, thanks for your input. I tried taking up the carpet on the transmission tunnel and found it very difficult. So, I ran the cable through a white plastic pipe which runs next to the door sill. This seemed to be the easiest way. All now installed and working. Thanks for your help.
Old 07-17-2006, 02:29 PM
I ran the power for my amps down the center console but ran the RCA's down the driver's side.
