Old 01-06-2006, 10:56 AM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Originally Posted by mbtoloczko
There has been some ongoing discussions on Nabisco about creating a gear oil cocktail for the 5MT to improve shifting and gear lifetime. One of the more popular cocktails uses Redline Shockproof. I was curious about whether Redline Shockproof is compatible with other gear oils, so I called up Redline to ask. The tech guy I spoke with said it was fully compatible with other synthetics and dinos.
Ah but unless it says it specifically on the bottle they're not liable should it cause issues.
Old 01-06-2006, 12:03 PM
mbtoloczko's Avatar
sans SVX
I hope the Redline tech guy is right because I'm running 75% Redline Shockproof and 25% Torco RGO in my 5MT.
Mychailo
Visit my locker
Old 01-06-2006, 12:32 PM
benebob's Avatar
Yeah, that's the reason I stay away from Redline plus there isn't any available independent verification of their stuff as they don't submit samples to labs to evaluate. They could make any claim in the world and without verification I won't use it. Granted many like their products and they aren't a fly-by-night snake oil producer which makes the suspicious side of me wonder why they don't go through the same process as the others do.
Old 01-06-2006, 05:01 PM
Whatever I end up getting I will get out as much of what is in there as possible.
The entire point is I'm looking for physical damage in there.
