Old 12-10-2005, 12:39 PM
shotgunslade's Avatar
Rahway Sighting
Saw a green or teal SVX with spoiler in Rahway or Carteret or Woodbridge, NJ (I don't know, not my neck of the woods). Returning from Leesville Auto Recyclers in Rahway0 about 12:30pm today.
Old 12-10-2005, 08:36 PM
Might have been Gary... MoreIBNR... He has a teal but he lives in Randolph. Might have been out and about
To,
