Old 12-07-2005, 12:39 PM
pavanbabut's Avatar
Question Need Error code explanation?
Hi all,
My friend is having a Nissan Maxima and it is showing 'check engine' light from quite a long time and he is not using it. Yesterday he took it to dealer for check-up and he told tht it is giving 0744 code and its a transmission-torque converter signal problem or something like that. But i need to know the exact problem for that code. Do anyone know about the explanation of that code? The car is around 97-2000 model.
thanks,
-Pavan.
Old 12-07-2005, 12:50 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
It's the torque converter. This'll give your friend a very good answer:
http://autorepair.about.com/library/...maximo+actuate
Good luck!
-Chike
2006 Steel Gray WRX TR (sold)
Old 12-07-2005, 08:58 PM
pavanbabut's Avatar
Good luck!
-Chike
Thanks chike for the link. Do you have any info on how to change it?
-pavan.
Old 12-08-2005, 12:39 AM
Andy's Avatar
Andy Andy is offline
Send a message via Skype™ to Andy
-pavan.
Easy. Just go the your dealer and say "I would like to buy a Subaru"
Oops, sorry, did you mean the torque converter?
Andy
If I would be a young man again and had to decide how to make my living, I
would not try to become a scientist or scholar or teacher. I would rather
choose to be a plumber or a peddler in the hope to find that modest degree
of independence still available under present circumstances.
-- Albert Einstein, The Reporter, November 18 1954
Old 12-08-2005, 07:40 AM
Chiketkd's Avatar
-pavan.
Nope. No clue. I'd take it to a dealer or an independent service shop.
-Chike
Old 12-08-2005, 09:54 PM
pavanbabut's Avatar
Does anyone know how to clear the CEL temporarily. My friend needs to renewal tht car and he is not using it at present, so he just needs to pass the smog check. So, we are thinking of disabling the CEL temporarily and work on it later.
Does resetting of memory clear off the codes temporarily? If so, how much time it would take to read the errors again?
-Pavan.
Old 12-08-2005, 10:56 PM
Chiketkd's Avatar
-Pavan.
If I remember correctly, the CEL on a Nissan will clear after 50 starts or you could just clear the ecu by disconnecting the battery for 20 minutes.
-Chike
Old 12-08-2005, 11:02 PM
pavanbabut's Avatar
-Chike
Yeh u r right, it is 40 starts. But, what I am thinking of is, will the CEl come on by the time we take it for SMOG, if we clear off the memory by disconnecting the battery?
-pavan.
Old 12-09-2005, 11:29 AM
Chiketkd's Avatar
-pavan.
It will if you drive it on the highway and the t/c tries to lock-up.
-Chike
Old 12-09-2005, 12:56 PM
pavanbabut's Avatar
-Chike
Then how about this, I will disconnect the battery somewhere near to the SMOG check and then i will take to SMOG check.
Does this works fine?
-Pavan
Old 12-09-2005, 01:14 PM
Chiketkd's Avatar
-Pavan
It probably will work just fine.
-Chike
Old 12-09-2005, 01:32 PM
Remove the bulb
