Old 09-09-2005, 10:26 AM
wawazat??'s Avatar
Yeah, I'm still around
Originally Posted by svxcuseme
Hello all. This is my second post thus far. I just recently purchased my 4th Sub, 92 SVX LSL Black, 115K. I'm in Atlanta but flew up to DC for this one and drove it home. What a cool car!
Welcome to the site. I have a question for you on how you drove the vehicle home. Did the seller let you borrow their plate? Did you get a transit plate? Did you bring on of yours?
I'm flying to Baltimore this weekend to bring one home and am curious on how others handled the drive home.
Thanks,
Todd
Down to none
Old 09-09-2005, 12:15 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Don't forget that no matter what one does to cure the ill the friction material in the tc may just be totally shot.
Old 09-09-2005, 01:06 PM
svxcuseme's Avatar
svxcuseme svxcuseme is offline
5 speed 4 sure
Todd...Thanks for the welcome. Glad to be here!
I took a Georgia plate with me and drove the speed limit everywhere. In Georgia you have 30 days from auto sale to register the car. If you get pulled over with a sign like "Tag Applied For" you can show your Title and Bill of Sale and be on your way.
Beav...What friction material are you refering to?
Old 09-10-2005, 06:31 PM
TC shuddering.
Hi welcome to the forum.
As you have a 92 model with 115k on the orignal trans, you could well have the flackey facing problem that affected some of those early boxs. The lock-up clutch on the torque converter, flacks pieces of facing off the clutch. These pieces end up blocking the transmission cooler in the bottom of the radiator, to prevent the oil from cooling and lubeing the transmission gears. Failure of the High clutch and planetary gears follow.( unless it was fitted with the filter under the battery)
Yours may have lost enought of the facing, to cause the shuddering, as it trys to lock-up. When you cleaned the screen in the trans pan, was there much debri there? I would check the oil cooler to see if it is blocked, reverse flush the cooler to remove any blockage. If the flair into 2nd continues, adjust the brake band.
Old 01-12-2006, 12:37 PM
svxcuseme's Avatar
5 speed 4 sure
Turns out my TC was not the cause of the shutter after all. Since I don't have a TC anymore, I'm pretty sure of that. Looks like it may be coil or plug related. Going to dig into the root cause after fixing my current and common stall issue.
