Old 09-16-2009, 06:23 PM
subiemech85 subiemech85 is offline
? remove panel below steering wheel ?
the one above knees that holds the switches?
searched: remove panel below wheel , 29 results not helpful
preparing to install remote start........
"Some work occaisionally is fine, but I bought the car for the road, not for the garage. " BoxerFanatic
click here for fuelly mpg info
Old 09-16-2009, 06:30 PM
MadMaxSvx's Avatar
MadMaxSvx MadMaxSvx is offline
Re: ? remove panel below steering wheel ?
You mean how to remove it??
I just pulled it from the lower part and voila!
95´ Subaru SVX EURO
85' Mercedes 190 2.3-16
86' Mercedes 190E
70' Olds Toronado
98' Renault Chamade
82' Honda Prelude
79' Honda Accord awaiting restomod.
69' Mustang Hardtop
67' Jeep Ford Willys awaiting restoration.
67' IKA Torino Coupe
74' Renault Torino Coupe
Old 09-16-2009, 06:33 PM
yes, remove
it seems to hang up in the middle
lower edges are free
Old 09-16-2009, 07:04 PM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
Remove the coin holder, power mirror, and parking light switches. Look in where the switches are and you'll see a couple screws. Remove them and also look for plastic molded tabs that have metal clips on the end of them. Be careful removing the cover so you don't crack the plastic.
On the left side near the vent will be a small metal clip that you slightly have to lift upwards as you remove the panel.
Remember to disconnect the light by the brake pedal and the winter wipers switch.
1995 Subaru Svx L / AWD
Old 09-16-2009, 07:06 PM
oab_au oab_au is offline
yes, remove
There are two screws behind the coil holder and the park light switch. It then pulls toward the steering wheel.
Harvey.,
One Arm Bloke.
Tell it like it is!
Old 09-16-2009, 11:07 PM
SVXalter's Avatar
SVXalter SVXalter is offline
Any trick to the port that's where the coin holder is on obd2 models?
Subiemech: I am putting a remote start in too, I may be able to help if you have any questions about wires.
-Dan
1996 Polo Green SVX L - 85k
1992 Ebony SVX LS-L - 193k (parts)
Old 09-18-2009, 11:38 PM
SVXalter's Avatar
any thoughts? haha i will just rip it out, hopefully nothing gets damaged.
-Dan
Old 09-19-2009, 01:10 PM
use pick to pull tabs towards center ??
Display Modes
