Old 08-16-2009, 01:35 PM
MiataMania's Avatar
MiataMania MiataMania is offline
42 Autosports
Send a message via AIM to MiataMania
ABS Pump Always On, Draining Battery....
Car is a 95 AWD, WRX 5 speed trans, some aftermarket 18" wheels, Hawk HPS pads AFAIK. All other drivetrain and brake parts are stock to my knowledge.
Here is a very strange one.
The Anti-lock brake light came on Friday night coming home from work while cruising. No shenanigans. I didn't think much of it, brought her home, turned her off and the next morning the battery was completely dead.
Messed with a few things, jump started the car, it ran fine, ABS light was still on but I was trying to figure out what was going on with the battery so I put that on the back burner. Went to get gas, drove it for about 20 miles, brought her home. She sat for maybe 5-6 hours, battery completely dead again.
So I took it the Autozone thinking the ancient battery (5-6 years old now) might be toast, but it charged up and tested as 'good.' I bring the battery home, start plugging everything up and as I start to connect the ground, the battery arcs and the ABS pump cuts on ( it is pretty quiet, I couldn't hear it with the hood closed) and ran. So I pulled the 45 AMP fuse out from the engine bay for ABS and it stopped, the ABS light also went off on the dash...
It has been sitting for a few hours and that was the only apparent power drain on the system because it starts fine now.
So apparently my ABS Pump wants to run and run...any ideas why? Any help will be appreciated!
Thanks,
Adam
Old 08-16-2009, 02:34 PM
NiftySVX NiftySVX is offline
Re: ABS Pump Always On, Draining Battery....
It is most likely the relay sticking on. They had issues with them
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
Old 08-16-2009, 02:55 PM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
+1 on the relay. Sometimes just tapping on the ABS case will stop it from sticking, as in my case (thanks to another forum member). You can also run the ABS codes.
Gene
Gene and Ben
Old 08-18-2009, 10:27 PM
MiataMania's Avatar
42 Autosports
Thanks guys. I'll try smacking it a few times to see if it cuts off next time I have a spare moment.
1990 Mazda Miata - Undergoing CSP Race Prep
1995 Subaru SVX 5MT - DD
Old 08-19-2009, 10:00 AM
svxash's Avatar
svxash svxash is offline
Ours was doing the same thing about 3-4 years ago and I tapped on the ABS pump and it quit and hasn't come back since.
1997 Boudreaux LSi
1994 SVX LSi(SOLD)
Kool Blue air filter, 4500k HID's, airbox mod, Hella horns, WRX 6 disc stereo, Infinity Reference and Clarion Pro Audio speakers, Infinity basslink sub, ECUtune Stage 1v5, ECUtune TCU, Power mode mod, Mad muffler mod v1.3
Old 08-20-2009, 12:18 AM
SVXalter's Avatar
SVXalter SVXalter is offline
Interesting info...
My parts car won't start on its own and the previous owner said the ABS got fried from flood damage. The ABS light remains on when the car starts along with the power light blinking. The windows and sunroof don't work either... Other than that it seems fine. Oh yeah and it's missing 2nd and reverse
