Old 01-16-2009, 09:25 AM
liamrh's Avatar
liamrh liamrh is offline
Crank pulley torque
So what does everyone button their crank pulley down too?
I am not real happy that the fsm says
"Crankshaft Pulley Bolt (1) ............. 108-123 (147-167)".
Old 01-16-2009, 10:36 AM
Maxo's Avatar
Maxo Maxo is offline
Re: Crank pulley torque
Yeah those values are the range that I torqued mine to...
Old 01-16-2009, 11:27 AM
torque spec ranges are usually for a new bolt vs old...
108 for a new bolt
128 for a used one...
I usually put it somewhere between the two, and for this specific one I use 110ft/lbs of torque
Old 01-16-2009, 05:54 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Quick Q on related topic.... which way does the pulley spin, looking from the front of the engine? Im assuming clockwise?
Old 01-16-2009, 08:14 PM
you are correct in your assumption
