Old 01-13-2009, 12:26 PM
wyldnwoody44's Avatar
wyldnwoody44 wyldnwoody44 is offline
Mechanically worthless Man : )
Door Lock ?
I have a lil problem with my locks, every once in a while the passenger side seems to seize up, Usually i can pry with a screwdriver and then it works again, I believe it just freezes here in buffalo, However since ive had the car the passenger side door does not lock with either the factory remote or when i lock the driver side door, Im curious what my options are as it has become really annoying locking both sides when i have a passenger Thanks
Old 01-13-2009, 12:39 PM
Re: Door Lock ?
You're saying the key won't turn in the passenger side? If that's the case I would try to lubricate the lock cylinder using some penetrating oil with the straw on it. After a thorough spray (be sure to protectthe paint on the door) put the key in and jimmy it around and it should free up. If not, I know crazy-pilot had a detailed post about disassembly and remedies to stuck locks. I have done the same for my car.
Old 01-13-2009, 01:50 PM
Re: Door Lock ?
The key works fine in the passenger door, its just that it wont lock when i use the factory keyfob or when i lock the driver side door. Ive read some other posts about this happening to the driver side door but mine is the passenger.
Old 01-13-2009, 02:50 PM
aust92pearl aust92pearl is offline
Re: Door Lock ?
same happend to my pearlie drivers door the lock accuator motor thingy had come loose and jammed
