help....
my car has a problem i was driving the other day and it shut off and i stopped on the side of the road and turned the key it started right up but when i put it in drive and touched the gas it died so i started it again and put it in drive and didnt touch the gas it would crawl for about 20 feet then shut off i have no clue whats wrong with it any help?
Is it giving a CEL? If so check the codes.
My mass air meter did that to me and it didnt throw any codes.
If your not getting a check engine light try lightly tapping on it. but check for codes first.
im not getting any codes ill go look again
now it wont even start just cranks
Do you hear the fuel pump running when you turn the key on?? Fold your rear seat down to make it easier to hear it. You should hear an electric motor run for about 5 seconds after you turn the key to ignition(not crank).
Yea the feul pump turns on i can hear that motor
3 turbos, 28 cylinders, 96 valves, 18 cams, 1400hp/1600ftlbs: '09 Outback XT / '06 Outback Sedan / '02 WRX / '94 SVX / '01 F-250 SuperDuty |
the stab in the dark answer is going to be MAF but you should still find a way to make sure you have fuel pressure and spark right now or replace the MAF
i think it might be the spark plugs because on some of them the housing is cracked i can see the wire on one of them.....
Try disconnecting the MAF sensor and see if it will run, late 98 JDM impreza has the same MAF sensor and gives the same problem when they fail.
I had 2 go on mine withn 2 weeks of fitting an HKS induction kit, the car would run enough to move it/ crawl it home at low speed when the MAF was disconected. Are you using the standard airbox or aftermarket bolt on cone filter? The sensors are very unreliable with cone filters or any vibration. Darren
11/94 SVX Alcyone, Mica Black, VL Spec 4WS, 71K Miles, 1 owner from new & was part of a private car collection in Japan. Nissan R34 Skyline Stagea 91 Lotus Elan SE Turbo 1966 MGB Roadster, Tarten Red, Wire Wheels, Leather, 23K miles from new You can tell the men from the boys from the speed of their toys. |
alright ill see if that works its too cold and too much snow to go outside right now...my name is darren too hah
