Old 05-02-2005, 08:39 AM
PatrickB's Avatar
PatrickB PatrickB is offline
Send a message via AIM to PatrickB
i hope its not a head gasket
Old 05-02-2005, 08:41 AM
tman6429
I know its not the Head gasket. Theres no water in the oil or no oil in the water. So i am safe from that.
Old 05-02-2005, 01:23 PM
I promise you it is a head gasket, as much as I don't want to. The symptoms of the heat and the temp all points to it. The dealership will probobly tell you the same thing. SOrry to be the bringer of bad news. Thats a sweet looking ebony though good luck with it.
Tom(Now I know why you got such a good deal)
P.S. Do me a favor and look underneath the oil filler cap. Is there a white or yellowish gooey substance?
Old 05-02-2005, 01:28 PM
SVXer95 SVXer95 is offline
Word to Yo Motha
Are you getting a CE light?
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
Old 05-02-2005, 05:16 PM
tman6429
I am soooooooooo relieved. I just got a call from Subaru dealership. Its the water pump, and its siezed. So far the water pump and timing belt needs to be changed. As for the timing belt the siezed water pump ripped small pieces of it. So i am so happy....... WOOOOO HOOOOO!
Old 05-02-2005, 05:30 PM
Surprising. I guess your pump didn't seize fully. Lucky! That is one sweet exterior.
Anyways, take off your crank pulley and clean the crank shaft. When my wp seized I only drove it like a 1/4 mile but oil or something baked onto it an I didn't realize it til 2 years later when I was doing some front end work.
e: Er, by crank pulley I mean the one in the timing case. Also make sure they cleaned your other timing pulleys and there is no baked t belt rubber on them.
Old 05-02-2005, 07:49 PM
huh, beats my guess. All the signs pointed to headgasket though, oh well
Old 05-04-2005, 07:49 PM
tman6429
Ahhhh what a relief. Me and my dad took the whole day to put the water pump on along with a new timing belt. It was pretty easy basic common sence and wa-lah done. It runs like a champ. Soon as i get paid i am changing the oil, oil filter, fuel filter, tranny fluid, replacing brakes front and rear, air filter, tires, PCV vavle, spark plugs, and adding a tranny cooler. Couple ???'s
How many quarts of oil?
How many quarts of tranny fluid?
Whats the best oil to use on these car? BTW cars has 85,XXX miles.
What type of spark plugs. LOW BUDGET.
Well One more ? i know my wheels are on backwards, which way is the right way.
Thanks.
Old 05-04-2005, 08:44 PM
fl_svx
Thanks.
The ones that say L go on the left, the ones with the R go on the right. The top of the star goes forward, make sure the tires are not directional, again with arrows...or they will be backwards.
I have always used castrol GTX until Syntec Blend came out, I now use Syntec blend for all my cars. Don't use Quacker State unless you want to live with the smell.
Old 05-04-2005, 08:58 PM
tman6429
What kind of tranny fluid Dextron or ATF? I am unsure.
Old 05-04-2005, 09:03 PM
dextron III
Old 05-05-2005, 02:47 PM
Earthworm's Avatar
Meow!
Best to have 7 quarts of oil each. It depends on how you are with oil changes. If you change exactly every 3000 miles and the car's not exposed to extreme temperatures you can get away with regular oils.
I personally use synthetic as we can see +40°C and -40°C throughout the year. I also like how it pours when it's cold compared to conventional oil.
As for plugs, don't cheap out. Get NGK PFR6B-11's because after you change the plugs once you probably won't want to change them for a long while.
Old 05-06-2005, 01:06 PM
PatrickB's Avatar
FYI just so u know that isn't the only way to tell if u have a blown hg. u can get exhuast in coolant and make your coolant bubble.
