Old 04-05-2005, 10:00 PM
Bizarre Bizarre is offline
Send a message via AIM to Bizarre Send a message via Yahoo to Bizarre Send a message via Skype™ to Bizarre
o2 sensors
Code 37 is still coming on after dual o2 (Walker) and h20 temp sensor replacement. Strange. I might have bad wiring connection; I hope.
Anyone have the CPU trip code 37 after O2 sensor replacement?
Biz
'95 SVX LSI Black, just wire mod.
New speakers + homemade front mounts.
"In times of peace, a gentleman keeps his sword at his side." Sun Tzu c 300 b.c.
Old 04-06-2005, 08:50 AM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
Send a message via AIM to Budfreak
i can't remember but aren't the walkers the ones you have to splice on? if so ditch that junk and go get the ones ready to go. i heard the splice on's are garbage. i had the dealership change mine and ended up getting a bad one on the passenger side right out of the box so it could just be bad right out of the box. try switching them around and see if the code changes.the o2 sensors for these cars must just be junk right from the factory.let me know what you find out.
Old 04-08-2005, 10:28 PM
No splicing. Normal connectors. I like the switching idea. I will give it a shot.
Old 04-16-2005, 09:26 AM
Hey team,
Switched the sensors, and code 37 still comes one. Irregular signal from left O2 sensor. Good news is both sensor are good out of the box. Bad news is either the left side connector or wiring is bad, or the left side of my engine is bad.
Darn. I might have mucked up the connector while diggin around in there. Has anyone tried to replace the connector/wiring?
Biz
Old 04-18-2005, 01:45 PM
Earthworm's Avatar
Meow!
Hmmm, timing belt jumped?
Old 04-20-2005, 08:51 PM
What do you mean by jumped?
Old 04-20-2005, 08:59 PM
Earthworm's Avatar
Meow!
It skipped 1 or more teeth so it's out of alignment and one bank of the engine is running with incorrect timing.
Old 04-21-2005, 05:57 PM
What would that do in the long run?
Any easy diagnostic to detect that?
Old 04-21-2005, 07:20 PM
immortal_suby's Avatar
Thread Killah
One sure way to detect it is to take the covers off the front of the engine, rotate it to TDC and see if all the match marks line up on the cams.
Locker Link
2015 BRZ Limited 6MT
Old 04-23-2005, 10:49 AM
Pardon my ignorance. What is TDC?
Old 04-23-2005, 10:54 AM
Thread Killah
Top dead center - basically when the #1 piston is at the top of it's travel. There is a mark on the crank gear and on the motor behind it, when that mark is lined up then you check the same type of mark on the cam pulleys and the motor behind them and they should line up.
Locker Link
Old 04-23-2005, 10:56 AM
Thread Killah
crank gear mark and engine mark
cam pulley mark
mark on engine behind cam pulley
Locker Link
Old 04-24-2005, 09:41 AM
Well that explains it. Thanks!
How hard it is to get those covers off?
See my locker for how hard it was for a stealership.
