Old 09-10-2007, 09:10 AM
Disillusion Disillusion is offline
Send a message via Yahoo to Disillusion
Mechanic disabled my alarm.
I had a fuel issue with my '96 SVX Lsi, and when I got it back from being fixed the mechanic disabled the car's alarm and keyless entry. Any ideas on where to start looking to fix the problem? The security button doesn't do anything right now.
Old 09-10-2007, 09:28 AM
JaySVX's Avatar
JaySVX JaySVX is offline
I'd take it strait back to the mechanic and say "fix what you broke", but other than that, try the fuse box.
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 09-10-2007, 09:32 AM
Good call, but trying a few things would be a lot less hassle. The place is kinda far away.
Old 09-10-2007, 09:44 AM
angrydan angrydan is offline
Are you familiar with the process to reprogram the remote? I guess it is possible that when it got disconnected, the security system lost its memory. If you haven't already tried this... I would start there. Its quick and, even better, free!
If you do not know how to do this, check out this How-To:http://www.subaru-svx.net/photos/files/How-To/27326.pdf
Dan Taney
1996 Subaru SVX LSi (Red)
2019 Subaru WRX LTD
Old 09-10-2007, 04:37 PM
jeffast jeffast is offline
I kill more trannies then god
aside from reprogramming the remote, and changing the batteries, don't try to fix it yourself,
if that doesn't work take it back and make him fix it or he isn't liable.
1991 xt6 eg33?
1993 gc track car
Old 09-10-2007, 05:25 PM
Seraphinwolf's Avatar
Seraphinwolf Seraphinwolf is offline
H6 THE ONLY WAY!
Send a message via AIM to Seraphinwolf Send a message via Yahoo to Seraphinwolf
The file is here now. http://www.subaru-svx.net/photos/files/How-To/19766.doc One thing though it contradicts it's self. the first part it says hit the botton 2 times each for 2 remotes then it says 1 then 3 for the first and second. Does it matter which? Guess it's not a problem least you only have 5 minutes to do it and HAVE to leave.
94 Bordeux Pearl LSi (Jun 2009) 109k Plate:GADDIS
What they call it a vanity-plate. Shouldn't I be obligated to be vane with it?
Rota Tarmac 3's 18x8" on 245/40/18 Dunlop SP Sport 600's, Perrin light weight crank pulley, PRW radiator, custom coilovers(not GC's), 9006 HID 4300k 50W low beams, DIY garage door lip, and SVXfiles brake kit. Fixxed exhaust so no more sweet sound.
97 White/Black trim Impreza Outback Sport (March 13/08) 150K-180K(sensor broken)Good news is EZ30R and 05' 6speed full powertrain swap is in motion!: Will be doing more work as I can. Gonna be run by a Hydra so yeah fun to be had.
[SIGPIC][/SIGPIC]
-Gaddis
Old 09-10-2007, 09:26 PM
fixed
All better! The remote just needed to be reprogrammed. Thanks a lot for the help!
