Fuel Injector Seal Kit
Does anyone have any thoughts on using the following fuel injector seal kit? It contains the filter and two Viton o-rings per injector. I am debating opening the injectors up and resealing (currently the rails are removed) but I would like to avoid paying the crazy amount for the OEM if possible.
Link to product: http://www.ebay.com/itm/OEM-Quality-...26d0d2&vxp=mtr
1994 SVX LSi JDM Tailbar and Grill, Clear Corners, 15min-mod, Nevin Blue RSB, G-FORCE SPORT COMP-2 Tires, Phenolic Spacers (Manifold & Throttle Body), SS Brake Lines, Maniac Electric Motors 160A Alternator 2008 Legacy 3.0R |
Re: Fuel Injector Seal Kit
That kit is probably fine. I've never tried changing the filters. You'll be breaking new ground if you do. Use petroleum jelly on the o-rings and fuel rails when you install the injectors or the o-rings will tear and leak.
Just send off your injectors to Deastchworks or some other injector rebuilding/flowtesting company. It only costs ~$20 an injector and you don't have to worry about breaking anything. Plus, you'll get a chart that shows how much your injectors flow and they'll be shiny again.
1992 Dark Teal LS-L w/ 165k+ miles (traded ) Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs 2001 Black Toyota Sequoia (hauler/daily) 1992 Blue Toyota Cressida (drift car) 1992 Red Toyota MR2 (weekend/track day car) |
I got my reply back from Mr Injector. He accepts Fuel Injectors still on the rail (he has a tool for removing them). This is the route I am going and they have already been boxed up. The cost is $17 per injector and with the flow test and cleaning it seemed like the most practical choice.
For those interested I will update with my results.
Sounds like a good plan.
"Peace is the flower of justice." |
