No start issue & cracked timing housing... and starter
I've got 2 problems I need a hand with on the same car....
Problem #1 Looking for ideas on a 92 SVX I can't get to turn over. the car was running rough and was leaning towards an issue with maybe the coil packs- so was going to transfer them off a another 94 SVX with relatively fresh coils and new plugs and see how far that would clear up the problem. Now the 92 with the issues has been sitting for about 3 weeks in a garage in a WI winter and now when turning the key to start, it won't start. Up till now, that was never a problem with it. I can smell a bit of fuel and a fresh battery was put it. I can't get it to even 'bump start' to get the crank pulley off to even start digging into my other problem listed below.... Problem #2 The bottom of the passenger side of the timing belt housing that's attached to the block has a crack in it and alot of oil leaked out from there. One of the corners that a bolt passes through from the passenger side outer cover is where the crack is. I found this pic and it's #5 -> Cover cp-belt, no2 right hand part number: 13532AA002. Any way to get this back cover off to replace if I cant get the crank pulley off? I'm in a catch 22 with these 2 probs- any ideas? thanks! john Last edited by Heat Seeker WS6; 03-11-2011 at 05:59 PM. |
Re: No start issue & cracked timing housing
If it won't even turn over, you have a power or starter issue, which will need to be addressed before going any further, try a know good battery in it before going any further.
#2 The timing covers don't seal up oil leaks, they are just dust shields, and the car can be run without them...so you have a seal leaking behind the cover, probably either the crank seal, or the cam seals.
I agree with you on the starting issue- I can't proceed without it at least turning over. We put in a new battery already and no change while trying to start. (still nothing beyond lights and dash lights turning on when attemping to start.) After work today we're going to look at power/ground wire issues & then starter. Maybe bad starter solenoid? Also, could that 'security' button w/ the red light under the instament cluster have anything to do with this? To me that button seems like a type of starting interrupt switch. #2 response: There's no oil in that area? After sitting for 3-4 weeks, we have about a quart of oil under the car and it looked like it origionated from that cracked regoin. (lower passengerside). The oil filter area was dry of any oil and it didn't seem like the dain plug seal went bad. I do plan on pulling the drainplug to check the integrity of its seal though. Up until this point of sitting for this long, it would do a little bit of spotting, but nothing substantial. Are the crank / cam seals prone to leaking? Referring to when exactly where that crack is... looking at part #9 on that pic above, its the innermost of the bottom bolts; and the crack is in part #5. Last edited by Heat Seeker WS6; 03-07-2011 at 11:57 AM. |
On the seals, yes, the cam and crank seals are prone to leak after they get some years /miles on them, and most of these cars are almost 20 years old now, so most of the seals and gaskets could stand to be replaced.
Have to pull the timing belt to do those seals, and the oil pump seal is also on the front of the motor, and should probably be done at the same time if you have that bad of a leak.
save yourself some time and just jump positive battery power to the signal wire on the starter, if nothing happens smack it with a hammer.
I'm up here in Sheboygan, if you need a hand, or a spare starter to test, just let me know. Otherwise try doing what the others have said to see if the starter is dead or what's going on. Do you get anything when you turn the key? clicking, anything?
