Old 10-03-2009, 12:34 AM
The1One1AndOnly The1One1AndOnly is offline
Heater Problems
I don’t know what happened, but my AC blows air out perfectly. As soon as I switch to heat nothing comes out of the front, only the side vents. Is that normal, or am I having some problems?
Old 10-03-2009, 04:27 AM
want-a-fast-svx want-a-fast-svx is offline
Send a message via AIM to want-a-fast-svx
Re: Heater Problems
hmm i thought with the heat on that the air is supposed to come out of the vents by your feet.
Old 10-03-2009, 09:14 AM
Green1995SVX's Avatar
Re: Heater Problems
That is correct.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 10-03-2009, 06:15 PM
Re: Heater Problems
Ok well since that is the case I would suggest looking under the dash at the actuators that control the blend doors and have a look at what is going on. If you find a door that is stuck or the arm broken or whatever you might be able to close/open the door manually to verify where said door directs air flow. Your problem lies somewhere under/behind that dash.
