Svx 6 spd conversion
Jut wondering what it would take to do a 6 speed conversion and what tranny and parts it would take.
Thanks Phill |
Phil,
PM TomsSVX and SubaFreak - they've both done 6spd swaps. -Bill
Alright thanks guys.
lata Phill |
Money....
The 6 speed ain't cheap and neither is the r180. I got lucky and got a good pirce on a previous car so I could afford it. I also got a steal on the parts. Tom |
Its possible to do the 6MT conversion without installing the R180. All you need is 3.90 ring and pinion gear from an R160 with a 3.90 axle ratio. The mid '90s Imprezas have this axle ratio. This is what I did this for a customer in Switzerland. Then the 6MT install is not much more difficult than the 5MT install and not quite expensive as doing the R180 option.
I only used the R180 becuase it was at a good price to begin with. I didn't feel like blowing up an R160 if I began to make more power. The SVX should have been equipt with an R180 to begin with, but that is a whole different discussion
Tom |
Awsome So it would work if i found a new impreza parts car with the 6spd and the rear 180 diff?
Phill |
Yes but the pedals need to be fabbed up and the luinkage needs to be extended... yada yada yada.
Tom |
