Front Axles!!!!! H E L P ! ! ! ! ! !
I've been trying to buy a reman axle for my 1995 AWD SVX! Some manufacturers have one part number for "all front", but each store (Autozone, PepBoys, Napa, locals) has another manufacturer that shows an AWD part# and a FWD# (DIFFERENT PART NUMBERS AND DIFFERENT PRICES!) The local dealer AND SubaruParts.com have TWO DIFFERENT PARTS for AWD and FWD!
I've been told by some very reputable people (like Beav) to not worry, but my brain does not compute a logical explanation for the "one part/two part" dilemma. CAN ANYONE EXPLAIN THIS TO ME, SO I CAN GET THIS FIXED WITH PEACE OF MIND? Thanks Y'ALL! P.S. The numbers I got from SubaruParts.com are: 28021PA061 [AWD] about $270 28021PA070 [FWD] about $320.
Jim 1995 Laguna Blue SVX AWD L - 240K (daily driver) - "ReBuILT" used engine at 236K miles (6/13) 2013 Veloster Red - Driver Now??Dropsprings [1/2" rear, 1" front] with Koni Strut Inserts> Magnaflow Exhaust System> ECUTune Stage 1av1 Upgrade (from 1v4)> ECUTune TCU MOD> Aluminum Crankshaft Pulley> Stainless Brake Lines> Phenolic Spacers> Perforated Brake Rotors (dint like, OEM now)> SmallCar Shift Kit (resting since TCU MOD)> 7-Position Ground System> High-Pressure Fuel Pressure Regulator (resting)> ATF Cooler & Campaign Filter> Yellow Polish Polyurethane Bushings> Pioneer Double-DIN Stereo with JL AUDIO Speakers> Driveshaft Rebuilt with C-Clip U-Joints> 15 Min MOD> 20 Min MOD .. . (2011) Valentine One Radar Detector with Remote Display - ucan'tseeme! Last edited by James Scott; 09-25-2003 at 08:16 PM. |
I don't know what the differance is, but I do know they will enterchange ...so get the cheaper of the 2
And you might want to get a reman, instead of a brand new one. www.rockauto.com has them for ~62 dollars +core charge (which you get back when you send your old ones in). I just got mine from them yesterday, they look great.
I think if its like the 1 generation legacy, the FWD axels are a liitle beefier so they can handle all the power, but they are inerchangable.
I GIVE UP!
Noone had a definitive answer, so I'm gonna go with the "best" explanation to date: It doesn't matter, because the differences must be inconsequential (like cosmetic) - They must work in each application. Svxsubaru1 had the best explanation>> Hope you're right bro!
Thanks for your input, gents!
