Just hosed off engine and...
RPMs started fluctuating rapidly, the car was slow, and it stalled as I pulled into my driveway. Will it be alright if I let it sit for a while? Is it misfiring?
Haven't had that happen with my SVX yet but that has happened with my Justy. I could barely keep it running. It got better after about 15 mins though.
Did you pressure wash it or just with a hose? Check all the hoses to see if any are either cracked or disconnected.
I pressure washed it in a self spray car wash. It ran fine for about 5 minutes, then the problem started getting progressively worse.
I just checked the hoses and found nothing. Can I hurt it by trying to start it?
I'm wondering if even a cracked coil pack may cause this?
Look for any brittle hoses or anything rubber getting brittle under the hood. I figure 10 years is a normal life span for rubber car components.
Typically there are places/things you shouldn't blast water into, however most will eventually dry out. In Arvada that may be around May or June. Just kidding (ain't I a Richardhead?)
If it starts fairly easily let it run for five or ten minutes and shut it off, the heat from the engine will help the drying process. If it doesn't start fairly readily don't force the issue, you'll just end up flooding the engine and making it more difficult to start. In that case try getting it into the garage (hopefully you have one and it's heated.) Chin up, this is one of those 'learning experiences', "being careful when washing the engine" and probably "not washing one in the winter". Good Luck
I went outside, started it and it was still doing it. So I revved it to about 3000 rpm for a minute or so and now it's idling fine, although there's a clattering coming from the engine. It may have been doing that before though.
Went on a quick drive and it seems fine. I guess this rules out the boot or hose theory. Thank god!
Thanks Earthworm and Beav. I think it's fine now. I'll use caution when doing this again. Last edited by DavieGravy; 12-27-2002 at 04:24 PM. |
Dick ************** 1999 Legacy GT 30th Anniversary Edition 2001 Outback Sport |
Could be alluminum ally. Not sure since I'm not the original owner. They're a SOB to keep clean though.
wuz gonna ask the same thing:
Car looks great but
I wanna see a picture of the clean motor.
Randy (Cleanliness is next to?) ii |
Re: wuz gonna ask the same thing:
Lwin M. Maung (Member # 147) Current SVX: • NONE Previous SVXes: •1994 LE Barcelona Red 107k • 1992 LS-L Pearl White 143k • 1994 LSi Bordeaux Pearl 220k • 1992 LS-L Ebony Pearl 184k • 1992 LS-L Liquid Silver 145k • 1992 LS-L Liquid Silver 102k • 1992 LS-L Ebony Pearl 123k Other current cars:•2001 Jeep Grand Cherokee Black If at first you don't succeed, CHEAT!
wheels...
Someone at the 10th meet has some stock wheels they had beed blasted (or stripped) of the paint down to the aluminum, and then polished....really looked great! The car was a Teal..sorry I can't remember whose it was
Shadowyng bought a set of wheels, and was going to do the same thing for his black SVX; haven't had an update on his progress...
Tom 92 Liquid Silver LSL 85 BRAT GL 81 280ZX 91 Legacy wagon 86 Pontiac Parisenne (55k) 86 Kawasaki ZG 1000 Concours 81 KZ 1000 LTD (shaft) |
