Old 11-09-2002, 01:35 PM
drivemusicnow's Avatar
Poor College Racer
Fender side marker lights
Just wondering about them... I have seen them on a few SVX's and I like how they look... I was wondering where you can get them and how hard they would be to install.. thanks
Greg
97 Red SVX LSi clean
96 Black SVX LSi beater
90 Red Eclipse GSX track ho
99 Ford F250 work horse
Old 11-09-2002, 07:54 PM
greg
I don't know....
But I was wondering the same thing. I like the white ones. The orange ones I have seen are not as sleek looking. I bet you just drill mount then wire??
-G
Old 11-09-2002, 08:36 PM
nubs's Avatar
nubs nubs is offline
Multiple Suby Owner
Re: I don't know....
-G
If they are like other Subaru's, they should be inset into the fender.Which would require a special fender. I am sure you could just fasten them on, but I think it would just look bad.
Old 11-09-2002, 09:53 PM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
Will post pictures.
lwin
Lwin M. Maung (Member # 147)
Current SVX: NONE
Old 11-10-2002, 02:26 AM
museumquality
i just mounted side marker lights on mine last week. i used clear with starndard orange bulb. at first i had them wired to work with the driving lights only, then we wired to turn signals only, and this is where i will leave them. the install wasn't tuff, i wanted to mount them lower then you normally see them stock- basically in-line with the front lights. i spliced into the + of the front signals, and grounded out on the chasi. the cutting was tricky at first, i started with a drill beleave it or not, then stopped when the metal started getting to hot and start to warp around the bit. i then borrowed a neumatic 3 inch circular grinder, and cut my pattern, it went fairly clean. i then filed the rough spots and then neutralized the exposed metal, then primered (with a small hobbie brush)and then drilled out the mounting holes, conditioning them as well. that was pretty much it.
keep in mind if you decide to mount lower on the panal like i did, you will need to bend some of the inner soft frame work. i will post jpgs later sunday here and locker.
fyi, i did not remove corner panels to do this, simply the wheel-well liner and the front corner light was all that was needed for access.
looks great on the red. also, look on ebay, currently there is a used corner panel up for auction , it has a marker mounted on it, looks stock-
jimi - to sleep now
Old 11-10-2002, 09:52 PM
museumquality
found this site that offers mini markers as well,
http://www.terrshop.com/
i will post a jpg of my lights monday
jimi
Old 11-12-2002, 08:26 AM
seasvx's Avatar
seasvx seasvx is offline
Re: Fender side marker lights
...didn't the cars exported to the non-US markets (as well as the home market cars) all have them? I seem to remember looking at pics in the personal lockers of our members in Europe, NZ and Oz and seeing them on their cars. How 'bout it, you guys?
Old 11-12-2002, 11:08 AM
Here are the part numbers for the OEM side marker (repeator) lights. The UK-spec and the JDM parts are identical, except for part numbers. Here they are:
UK-spec
repeator (right) PN 84401PA020
repeator (left) PN 84401PA030
The cost is £26.53 ($42.13)plus shipping
JDM
repeator (right) PN 84401PA010
repeator (left) PN 84401PA000
I don't have the actual cost on these, but they are definitely cheaper than the UK ones. Probably about $26.00 each. Maybe Lwin has the price.
These are complete assemblies, with amber lenses, bulbs, gaskets, and wiring harness. Attached is a good photo of the marker. I also took measurements on this car, when I was over in England, to show the correct position.
Old 11-12-2002, 11:53 AM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
John,
Looking at that picture, they do not appear to be inset into the fender. Do you recall if they were?
I think they should be inset. I really like the new clear audi markers, I think they would compliment the SVX. I'd like someone to make a bolt up flanger to make the inset for the fender. Then won't have to take my portable sheet metal nibbler out this holiday season and get a set
Doug
1994 LSi (4/93)
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Old 11-12-2002, 12:08 PM
They weren't inset as far as I could tell. I did some very close inspection when measuring, etc. What I really wanted to do was pop out the marker and make a "rubbing" of the shape of the hole in the fender.
Speaking of side markers, I like the wraparound ones that are inset into the bumper and wrap around the front wheel well lip of the new Porsches. Visability and functionality integrated into design.
Old 11-12-2002, 05:44 PM
museumquality
Here are the jpgs of my clear side markers. (blinker only)
Old 11-12-2002, 05:45 PM
museumquality
another
Old 11-12-2002, 05:53 PM
museumquality
Old 11-27-2004, 01:14 PM
pavanbabut's Avatar
Hi all,
i just bought side marker lights for my SVX. I have no idea on fixing them. Some of u guys have successfully installed. Can u guys please tell me how i can install them.
1) which tools i require
2) The dimensions (HXW)
3) Procedure to install
Can i install them myself and is it too tuff, I want to use them as blinkers.
Thanks,
Pavan.
Old 11-27-2004, 02:51 PM
paddlesnz's Avatar
paddlesnz paddlesnz is offline
Send a message via Yahoo to paddlesnz
JDM
Y1850 each plus 5% tax.
paddlesnz
1993 Subaru Alcyone SVX
1980 Isuzu 117 Coupe Giugiaro Edition
1999 Mazda Astina
2006 Honda Legend
2006 Toyota Mark X Premium
2007 Toyota bB
2007 Mazda Roadster RS
2012 Peugeot 208 Allure
