Old 02-20-2014, 03:01 PM
Svx95's Avatar
Svx95 Svx95 is offline
eg33svx95
"Click" when braking ONLY in "P" located by shift lever
Just like the title states it, my 95 svx has a loud click right below the "shift lock" mechanism letters when I press the brake to shift out of "P". It only clicks when the ignition is on ACC or ON position also only when shifting out of "P". The click can be felt if I touch the gear selector bezel. Any ideas, comments?
TIA,
Sam
Sam
Brilliant Red 95 SVX L AWD 149K miles - #904/1801, 08 STI 6MT with DCCD & VSS, ACT SB10 HDSS, 6MT bushings, DW200 Fuel pump, 17x7.5 VX-SCYTHE Wheels, 17x8 BBS STI Wheels,PERRIN CRANK PULLEY, 911 Turbo oil filter,$15/15min MOD & $20/20min Mod, Brontrager WORKS 22mm RSB w/ QS component endlinks, SS Brake Lines, DDM TUNING 6000K HID LOWS, Hella Optilux Extreme Yellow Fog Lights,Window scratcher fix, JDM Clear Corners
Old 02-20-2014, 03:38 PM
Re: "Click" when braking ONLY in "P" located by shift lever
That's the solenoid clicking to unlock the shifter. It's connected to the brake switch. It's just doing it's job. The lettering is there to indicate the access point to release the shifter if the brake switch or solenoid fail.
