Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Brake Upgrades
Old 09-20-2013, 11:28 PM
Tapani Tapani is offline
Re: Front brake up grade to Wilwood 4 pot
Originally Posted by Dessertrunner View Post
Anyone know the bore of a STI,
Smaller bore then the SVX will mean more pressure on the brakes and therefor more stopping power with the same caliper.
http://forums.nasioc.com/forums/show....php?t=1456630
/T
Old 09-21-2013, 12:18 AM
'E''s Avatar
'E' 'E' is offline
Originally Posted by Tapani View Post
Svx master cylinder is 1/16 same as Sti
92 pearl SVX about to revive
92 Black 4ws (Jap spec) SVX
93 black SVX
93 Liquid Silver SVX - sti 6 speed with R180 diff, my05 sti steering wheel, sti alloy lateral links, 19x8.5 275/30 42mm offset front and 19x8.5 275/30 22mm offset on the rear, 6 pot brembo caliper with 355 rotors front, 2 pot brembos rear
95 bright red SVX
96 emerald pearl SVX about to revive
Old 09-21-2013, 07:52 AM
dragoontwo dragoontwo is offline
Originally Posted by 'E' View Post
Svx master cylinder is 1 1/16 same as Sti
Fixed it for you.
'92 SVX LS Pearl White - 6mt
Old 09-21-2013, 03:14 PM
'E''s Avatar
'E' 'E' is offline
Lol thanks
93 black SVX
95 bright red SVX
Old 09-21-2013, 04:14 PM
Dessertrunner's Avatar
Have removed
Old 09-21-2013, 06:47 PM
'E''s Avatar
'E' 'E' is offline
This is what I built for one of my cars
That looks awesome but why?
93 black SVX
95 bright red SVX
Old 09-21-2013, 07:21 PM
Have removed
Old 09-21-2013, 11:02 PM
'E''s Avatar
'E' 'E' is offline
I am using Matts rally car on the track now and from what Bazza showed me its important the be able to adjust the brake balance between the front and back by a simple method. Bazza would be better to explain his experiance. I am mucking around with realy heavy duty calipers from Wiwood.
Tony
Ok you're splitting the lines front and back, makes sense to me now
93 black SVX
95 bright red SVX
Old 09-25-2013, 07:36 PM
bazza bazza is offline
Excellent. That's good to know.
I'm not one for figuring out brake math ie, caliper size vs piston size vs cylinder size as I've seen so many people come up with answers which are opposite to what I see on the track or street.
But I know bigger brakes not only stop the car better but give far better control - I found the smaller piston and smaller rotors are prone to lock up far easier - the pedal is very "on" or "off". The bigger the rotor and cylinder - the more control you have and you can get closer to the edge without locking up. Obviously the more metal you have the more heat it will handle and the longer it will go before overheating / fading / boiling fluid. I have ally spacers, ally wheels, ally brembo calipers and at the end of a session - the rims are hot to touch - everything is sucking heat away nicely from the pads and they never fade or boil.
Tony, if that brake bias setup is for the track car - maybe consider deleting the brake booster. You'll get better feel and save weight.
Old 09-27-2013, 08:53 AM
Gamesy's Avatar
Gamesy Gamesy is offline
Why did desertrunner remove his info?
Old 09-27-2013, 02:46 PM
Tireiron Tireiron is offline
He got his feelings hurt by someone on the internet and is handling it like a mature adult.
