Old 02-13-2013, 09:09 AM
stiguy's Avatar
stiguy stiguy is offline
Snap- no pwr to the wheels :( diff?
So driving my 94 L fwd.
was getting on the fwy this morning had gottin up to about 60mph and heard one loud snap/bang. Then it rev'ed up. Pulled over and the engine was still running but wouldn't move in any gears. ... Maybe the diff snaped? I heard no grinding sound tho .... But the car has a ticking sound from the trans area before it stopped and still does after tho so idk if it has something to do with it.
Any ideas? It may be time for awd 5speed conversion
#1 1994 Ls ebony parts car-rip
#2 1994 L laguna blue - sold
#3 1992 Lsi pearl white - sold
#4 1992 Lsi pearl white -Ate two engines - Rip
#5 1994 L Laguna Blue fwd - Now Awd and manual - 03 wrx 5mt - 18's stern warp st4s - totaled hit a tree
#6 1992 Lsi custom orange parts car
#7 1992 Lsi green 4.44 swap. Currently for sale
#8 1992 Lsi custom pearl white. Project car... sold
#9 1992 Teal 4.44 swapped... sold
#10 1995 Laguna Blue. Sti 19 wheels,
#11 1994 Laguna Blue. Came with #10 engine and trans are out but plan to put it back on the road. Willing to sell it at any time! 😂
Old 02-13-2013, 10:40 AM
bishop bishop is offline
Re: Snap- no pwr to the wheels :( diff?
maybe the flex plate snapped?
Old 02-13-2013, 12:07 PM
^ Sounds like a flex plate to me too.
Replacing the flex plate requires pulling either the trans or the motor (or both). Use a phase 2 flex plate, as they are stronger. (Searching should yield the part number).
Old 02-13-2013, 12:57 PM
HERE IS THE UPDATED FLEXPLATE AND PART NUMBER
12332AA071
The old style plates were 2.05mm thick
The new style plates are 3.25mm thick
Old 02-13-2013, 02:27 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
K.I.S.S. check both axles first as if one snaps internally or externally car go nowhere.
Old 02-13-2013, 03:00 PM
Good idea, should be easy to check for. Although I have not heard of an SVX axle snapping before, I guess a FWD SVX would be the one to do it. Then, since it's an open diff, the engine would just rev like what he described.
The "ticking sound from the trans area" sounds like broken flex plate, but maybe a snapped axle would make a similar noise?
Old 02-13-2013, 05:14 PM
benebob's Avatar
My mom's old Turbo legacy did it after a friend bought it. His axle was bad for like 10k before it went but its a quick check with someone behind the wheel other looking down at the inner axle.
Old 02-14-2013, 11:13 PM
stiguy's Avatar
Yeah i am gonna check the axles first. If i put the front end on jacks and put it in gear will a wheel spin if one axle is broken?
.. I popped open the TC bolt access hole i saw the flex plate spinning.. and a few weeks ago i checked all the TC bolts so i know its not them.
Old 02-15-2013, 04:33 AM
benebob's Avatar
may move in the air but may not,
