help: power steering whine
did some research and cant find an answer.
In the morning when i start the car, there is a "whine" coming from the engine bay. After it warms up the whine goes away but as soon i start to drive it and turn the wheels, the whine is there. i put the car in park and it whines. this leads me to believe steering pump so i checked the pump and it is fine. any ideas? i replaced the steering fluid less then 3k miles ago. bad pump? the car is a little hard to turn, but i blame the age and weight and i havent drove another svx for a long while to tell the differences. Thanks in advance
VICSVX 94 SVX L AWD Conversion Barcelona Red First car and now being restored, 215xxx |
Re: help: power steering whine
Did you put steering fluid in or ATF like it's supposed to have?
And how did you "check" the power steering pump? |
Is the "whine" the belt squealing against the power steering pulley?
P/S pump bearing?
well i guess putting the wrong fluid could cause that issue...my bad. dee dee dee
how would i flush it? as for "check" i ment i checked the fluid level lol
it is not the belt i know for fact....it can be the bearing??? how would i check that??
also what ATF does it take? i dont have the owners manual.....
http://www.wuala.com/dbarnblatt/Photos/SVX/ |
Dextron II or Dextron III ATF. It tells you on the reservoir cap for the power steering fluid.
Regular P/S steering fluid is a no-no. .
On a side note, why no regular P/S fluid in our cars?
1992 Pearl White LS Owned since 2009 175k Miles STi Airlift Performance air suspension 2005 WRX manual swap Rear wheel drive K-Staff front bumper Delta Speed side skirts JDM clear corners Smallcar grille Subaru XT steering wheel Subaru XT shift knob First bagged SVX in the world Worlds first SVX on air suspension. Custom made (by myself) spare tire subwoofer. |
Because the pumps and rack were made to use ATF as hydraulic and lubrication.
PS fluid was created in the late 70's for no good reason really. Up until then, every MF required ATF or some euro brands may have already switched to a special hydraulic oil in the power steering system. PS fluid does not give the proper lubrication and protection to the steering system in a vehicle meant for ATF. Last edited by 1986nate; 01-29-2013 at 07:12 PM. |
thanks for the link...its a must for these cars lol
as for the fluid...i know i put ps fluid. so anyone know the best way to flush it??? thanks for the swift replies
You could disconnect one of the low-pressure lines to drain it out. Just don't let the pump run dry.
Getting back to the whine only when cold -- check your hoses to make sure they are tight at each end. You may be drawing air into the system, which causes bubbles in the fluid. Once the engine/fluid warms up, the noise goes away.
Bill
My guess it is the O-ring under the fluid tank - go to the How-To Docs to see how to do it.
The good thing is that you are emptying the reservoir of your PS fluid so that you can add fresh ATF. No more than 15 minutes. .
