Old 10-21-2012, 12:46 PM
VICSVX's Avatar
VICSVX VICSVX is offline
Never Forget
Another Window problem
Both front windows worked fine then one day the passengers side won't go down. I checked to make sure the motor was good by by passing the switch with an extra car battery. It went down, then I switched polarity and it went up. I put the Window back down and hooked the swith up again. It went up but not down. With the Window up I push up on the switch and you can hear the motor work. I switched switches from the rear same thing. I did the same test on the passenger rear Window but it work opposite (down but not up)
is it the master switch?
Thanks
obtw I did do a search and I did make sure that the Window lock button was not activated. Lpl
VICSVX
94 SVX L AWD Conversion Barcelona Red First car and now being restored, 215xxx
Old 10-22-2012, 04:15 PM
VICSVX's Avatar
Never Forget
Re: Another Window problem
Bump
anyone?
VICSVX
Old 10-22-2012, 04:22 PM
Try opening up the master window switches and cleaning the contacts. It worked for one of mine that was acting weird. If you take apart the master window switch, hold it upside down while you do, otherwise little springs and stuff will fall out all over the place.
Old 10-23-2012, 07:59 PM
VICSVX's Avatar
Never Forget
So I hold it upside down? Lol jow dono take it apart?
Thanks for the reply
VICSVX
Old 10-23-2012, 08:02 PM
SpecialFX's Avatar
SpecialFX SpecialFX is offline
I wish someone had told me that before I took mine apart a few months back! I managed to get the passenger window working again, but I never got the window lock button put back together right so now that doesn't work, lol
Old 10-24-2012, 10:46 AM
Yea I found out the hard way too, luckily I was at a desk so the little tiny pieces didn't get away from me and I was able to figure out how to put them back in.
Old 10-26-2012, 04:38 PM
VICSVX's Avatar
Never Forget
So I took my switch apart.... They contacts seem to be touching right on all 4 bu the Window stl only goes up. New switch?
VICSVX
Old 10-26-2012, 05:49 PM
Clean the contacts, may not be making a good connection even though it's touching.
Old 10-28-2012, 02:44 PM
VICSVX's Avatar
Never Forget
Thanks guys for you help and suggestions
I read about cleaning the contacts before I started this thread but am still curious on how the contacts get dirty enough to not conduct.... Just 20yrs of light dust?
Anyways to close the thread problem is solved
took apart the switch and made sure all contacts were touching at rest then I got contact cleaner for 8$ at parts store, sprayed all contacts lightly and bam like new.... So far lol
VICSVX
Old 10-28-2012, 03:14 PM
Rod.'s Avatar
Rod. Rod. is offline
Talking Re: Another Window problem
Windows 8 just came out but am not sure how backwards compatible it'll be... ;-)
Sorry, couldn't resist. Thanks for posting your solution. I've got the same problem that needs fixing.
Rod.
'97 Ebony LSi #426, CDM (1 of 51 in '97), 185k km, rebuilt engine & transfer case; 22mm Bontrager RSB; 4300k HID 9006 bulbs SOLD
'92 Ebony LS-L #6851, USDM (sold)
'08 Forester (wife's)
'06 STi (traded for the Forester)
'94 Legacy wagon (sold)
