Old 07-19-2013, 06:00 PM
FM977 FM977 is offline
Re: Duty solenoid C replaced, but still have the code
It may not be the solenoid. In my case, it was a bad TCU (the gold box under the dash). I believe it went bad when I sprayed the engine off at a car wash while it was running.
Old 07-19-2013, 08:36 PM
Dynamic Entry Dynamic Entry is offline
I am concerned that it will indeed require a new TCU, just like yours did.
But I feel like the Duty Solenoid should be addressed first, since the error code is evidence that it needs service.
I guess I should look for a way to test the TCU (other than plugging in a known-good one).
I would definitely prefer NOT pulling the tail off the transmission to replace the solenoid...
Old 07-19-2013, 10:41 PM
Harvey told me that the grease in the fuse holder is normal; intended to prevent corrosion.
And, the fact that my FWD is not working indicates that the TCU might be the primary/only problem, and that I should not necessarily act on the Solenoid Code 24 until making sure the TCU is proper.
Very good to know.
Old 07-25-2013, 07:48 PM
I bought a known-good TCU from another member, and plugged it in today.
Upon start-up, the POWER light still flashed 16 times.
With FWD fuse in there is still no FWD light on.
Wheels are still locked in some manner. Tight turns on gravel = some wheels grind/drag a bit instead of simply rolling
I don't understand what is causing the FWD to be Non-operational.
It seems like I will still need to do the Duty C Solenoid down the road.
At the moment I have the battery disconnected to try and erase any stored TCU codes.
