Old 05-30-2012, 12:23 PM
Counting CEL. Flashes
Any easy way to count the flashes . I am having a H 3 11 of a time . I am counting. And all of a sudden I realize. They changed to fast and I don't know if it is 4 slow and 5 fast or 3 slow and. 6 fast ( what ever )
Old 05-30-2012, 01:44 PM
dcarrb dcarrb is offline
Re: Counting CEL. Flashes
As I recall it's pretty straightforward: long flashes are maybe a one-thousand-one count, followed by rapid blinks. Then it repeats. Just watch carefully.
dcb
Old 05-30-2012, 02:13 PM
I understand the process. Morse code problem no matter how close I watch I can't tell when the long stop and the short begin. Long , long , short , short . I even tried making lines on paper and. Them count the lines .
Old 05-30-2012, 02:52 PM
A few years ago I needed to read the blinky lights on a 1990 Chevy.
Could not do it.
Got my 18 YO son Nick to read it for me.
Not a problem.
Old 05-30-2012, 02:59 PM
TurboIQ TurboIQ is offline
Film it with an Iphone and watch it in slow motion.
Old 05-30-2012, 03:08 PM
Looks like I have
37. Oxygen 2 LH
And a 57 EGR problem
I thought I had a 38 but makes no sense with a 5 speed
Whatq is the consensus ? Bad 02 sensor causing the problem
Running rich , sounds like driver side making the most noise.
Old 05-30-2012, 04:00 PM
Looks like I have
37. Oxygen 2 LH
Conn, I'm getting 56 (EGR system) and 34(EGR solenoid) on mine.
For me they always come together.
Might want to count them flashes again?
This reminds me, I need to clear those codes and run my svx through emissions.. it was due in march..
Stupid EGR...
Old 05-30-2012, 04:11 PM
Problem is the car is not running right. If I did have a bad plug or coil pack it still is ont on the code list. No injector showed up for sure. 0 2 won't cause it to run rich or lean? Seems like it has power , just feels like it is struggling on 5 or 4 instead of all 6....
Old 05-30-2012, 04:42 PM
You can take it to a dealer and have them read it on the Subaru Select Monitor. Otherwise just have a few other people try to verify your counts. I don't think those codes will make it drive worse.
Old 05-31-2012, 09:18 PM
I can confirm that codes 34 and 56 do not make my SVX drive worse.
If it wasn't for the CEL I wouldn't even know it was stuck..
Its been like that for 2 years now in my svx, even passed emissions just by turning off the CEL...
Old 06-06-2012, 08:12 AM
Do u think all the codes could come from loose plugs?
CEL is off now
Old 06-06-2012, 11:05 AM
95SVXL's Avatar
95SVXL 95SVXL is offline
Better yet film it with an android phone and watch it...
Old 06-06-2012, 11:49 AM
radarwhiz's Avatar
Fairmont State University
And I can confirm that code 37 (LH O2) does make it run worse. It stumbles and hesitates like OP said and idles way too low but never stalls. 37 is the only one I've ever had and it comes on consistently after a few minutes of normal driving. If I accelerate hard up to ~5000rpm or so it clears itself and is fine until next time I start it. No answers on a cure though.
Elazar
'08 ML550 daily driver
'13 F150 work truck
'87 MR2 racecar
'92 Lsl Claret 5sp
Old 06-06-2012, 02:18 PM
How tight do you tighten a spark plug? I was told TIGHT you have to crush the crush washer. Repair guy used a torque wrench. He said about 15 lb. also said about 1/2 turn after finger tight . Not as tight as a bolt.
Car up and running STRONG .....!
Old 06-06-2012, 08:56 PM
Good to hear conn, so it was the plugs?
