Old 03-01-2012, 05:26 PM
Re: Manual Swap
Originally Posted by rj7630 View Post
Thanks for the information. This will be a big help.
Also, how does the rear diff. work out? Can I just bolt the Leacy diff. in place? How about the LSD? Also, I remember reading that the axles for the SVX are different. If I can use the Legacy diff., will the axles be an issue?
If you want to retain LSD, if the replacement diff is not, you will need to swap carriers. A writeup can be found in "SVXfiles" signature under "4.44 swap", it will have details on the rear differential swap. The process will be the same for any other gear ratio as well.
