Old 01-22-2012, 03:23 PM
zavikan zavikan is offline
shudder at high speed w/ specific symptoms...cause?
02 hyundai sonata v6... the whole car shudders around 55-70 ( but not all the time?). Steering to either side makes it worse.
The other clincher is is that it only does it under engine load (RPMs don't matter). coasting, even in gear, at these speeds makes the problem go away.
I checked the rubber boots under the car, nothing ripped.
Other known issues:
Front tires are JUNK. unevenly worn on the insides, but then again, they keep going flat, (and I get sick if refilling)... corrosion on the wheels makes the seal bad. So I'm unsure if its just low pressure wearing them badly, or if its the alignment...or..tirods? or.....what.
warped front brakes, possibly a sticky caliper, though not sure.
'92 Liquid Silver SVX - Drilled&Slotted Rotors/Canadian OEM Seat Warmers/JDM Folding Mirrors/JDM Clear Corners/Euro Glass Headlights/Euro Headlight Level Adjustment/Euro Shifter Assembly/ECUTune Chip V.1/GARAGE QUEEN!
Old 01-22-2012, 03:34 PM
Green1995SVX's Avatar
Re: shudder at high speed w/ specific symptoms...cause?
It sounds like a bad axle, or axles to me.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
