Old 11-16-2011, 11:50 AM
waltweems waltweems is offline
92 svx starting problem
Recently my 92 will not start easily. if i let it crank for a while it will start and then drives normally. Next morning, same thing. I crank and crank and finally it starts. I replaced the fuel pump about 500 miles ago.
Please - any thoughts are appreciated.
Walt Weems
Old 11-16-2011, 02:26 PM
Re: 92 svx starting problem
Just curious ...Will it start easier with a jump start. Thinking maybe the battery is weak. If the battery is weak it may crank just a little slower than normal . You may not even notice that it is .
Old 11-16-2011, 03:05 PM
The Molinator
Does it turn over rapidly.. taking a few secs to start? .. OR does it turn slowly.. barely starting.. ?
Jim
Old 11-16-2011, 03:20 PM
Coolant temp sensor
