Best Tranny Cooler
Searching turned up too many results so i figured i would ask this here. Going to install tranny cooler before my trip up to the mountains this weekend. Need a little better cooling because I always see the trans temp light just before i reach the top of berthoud pass. I have LAN's tcu so i figure it's hotter than i want but not cooked yet.
1. What kind and what size did you use? 2. Gauge? |
Re: Best Tranny Cooler
For reasons I have stated in the past (miminum flow resistance and avoiding excessive cooling for cold weather), I like the following options, found at summitracing.com:
Flex-a-lite 4109 Flex-a-lite 4110 Summitracing SUM-G4966 Even the 4109 should still have three times the cooling capacity of the internal cooler, if I recall correctly.
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything |
LAN's recommended setup, a cooler inside the front fender with a thermostatically controlled fan should be good also...
Cheers! Gordon 1997 Ebony #308 113k "The Black Diva"SOLD 1992 Black over Liquid Silver 152k SOLD 1992 Ebony 251k 444 SOLD 1999 Silver SLK230 134k SOLD 1997 Green Outback 137k SOLD 2013 Honda Accord I4 SOLD 2015 Subaru Crosstrek 30k 2018 Tesla M3 30k |
so looks like fin type in the wheel well is good. gota get it done by friday so ordered one from napa and will put it in tonight/tomorrow.
I sure hope you also will be installing a proper gauge as well.
British vehicles are my last ditch attempt to keep the nasty Italian thoughts in my mind at bay. So far its working. |
cooler is a must, gauge also wanted. will probably have to order one as all the local shops stock gauges but not senders or kits to hook them up. anyone got a part number for a good gauge that works with stock sender or a kit that works well?
if the temp ranges are similar (I am not sure) you could just use one of the aftermarket engine coolant gauges with the fluid capillary tube attached to it, then replace your stock sending unit with the one attached to the gauge, (hopefully no drilling and tapping required) tighten everything down and then check for leaks.
2003 Baja Sport 1994 SVX LS 1992 SVX LSi parted out |
got the cooler installed in the fender well, pretty easy job and didn't see the hot light at all. seemed to shift better the whole trip up the mountains but maybe i'm just optimistic. i hope to find a gauge that will allow me to use the stock sensor on the trans to avoid the capillary tube, i don't like running fluids into the car.
Get a B&M remote filter kit from Summit racing - it is already tapped so you can screw a sending unit for an electric temp gauge in there. No need to run any hoses into the car. They use a large Fram PH8A type filter. You get filtering and temp monitoring without much hassle. I have mine mounted in the fenderwell right above where you put your cooler.
http://www.summitracing.com/parts/BMM-80277/
Matt Locker Link 2015 BRZ Limited 6MT 92 Ebony LS-L ECUtune Stage2av1, Z32 MAF, 370cc injectors, TomsSVX intake, BontragerWorks 22mm RSB #003, HID Hi and Lo beams, OT endlink and bushing mods, PWR Aluminum radiator, Harvey's QC shift kit, 2.5" flowmaster 80 exhaust, 17" Michelin Pilot Sport A/S, Poly sway bar bushings, Slotted Bradi rotors, AFBeefcake powdercoated calipers, 97 grill, and a huge set of air horns. 300,000 miles and counting 92 Ebony LS-L. ecutune stage1v4, motorsport 1pc pulley. Garage Queen - sold to Dad in upstate NY 155,000 miles 19 Subaru Ascent Premium - -Hers !. 89 DL 4x4 little red wagon - a.k.a. The immortal suby. 275k R.I.P. Last edited by immortal_suby; 11-14-2011 at 06:30 PM. |
will probably get that remote filter and adapt a sender to it if i can't find a gauge to work with the stock sending unit. seems like a pretty cheap way to go for an extra filter and the ability to add a gauge.
Thread Tools | |
Display Modes | |
