Old 10-14-2011, 07:56 AM
Gamesy's Avatar
Gamesy Gamesy is offline
brake flush
how much fluid do i need to completly flush my brake system?
Old 10-14-2011, 08:27 AM
Re: brake flush
One quart should be enough for a flush.
I use Valvoline 3-4 full synthetic.
Old 10-14-2011, 08:56 AM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Re: brake flush
Agree with OT. Unless you are one of the 1 percent who actually do it ever 2 years I would use nearly all of the bottle since it is useless after opening anyways.
Old 10-14-2011, 10:41 AM
Re: brake flush
if you want to be sure you got a complete flush they sell colored fluid in several different colors. just be sure not to get dot 5 which is almost always colored.
Old 10-14-2011, 11:27 AM
Re: brake flush
I use the ATE Super Blue Racing Fluid, DOT4. Has a much higher wet and dry boiling point.
Boiling point minimum: 536 degrees F
Wet boiling point minimum: 388 degrees
Designed to last up to 3 years under normal highway driving conditions
It comes in the blue color. I alternate between this and the ATE TYP 200 Amber fluid (which has the identical specs) when flushing the brakes to see the color change at the calipers. That way I know all the fluid has been changed.
Old 10-14-2011, 12:52 PM
Gamesy's Avatar
Re: brake flush
the reason why i'm asking is cause i looked at the fluid in the master cylinder and it looks all dark which if i'm not mistaken brake fluid is normally clear
Old 10-14-2011, 01:33 PM
Re: brake flush
Originally Posted by Gamesy View Post
the reason why i'm asking is cause i looked at the fluid in the master cylinder and it looks all dark. if i'm not mistaken brake fluid is normally clear
Usually a very pale gold or pale amber. Something like diluted Miller Lite, not gin.
Old 10-14-2011, 03:44 PM
Gamesy's Avatar
Re: brake flush
Usually a pale gold or amber.
hmm weird the fluid i got for my clutch master cylinder it was clear
Old 10-14-2011, 03:57 PM
benebob's Avatar
Re: brake flush
Most are more clear than amber.
Old 10-17-2011, 05:39 PM
Re: brake flush
Where is this available? I need to flush a system and would like to use this because of the different color. Thanks
Old 10-17-2011, 05:55 PM
Re: brake flush
Just so you know, the Valvoline synthetic 3&4 has a High Dry boiling point of 480°f
and a Minimum Wet Boiling Point of 311°f.
Stock is DOT 3;
Boiling point ranges [2]
Dry boiling point Wet boiling point
DOT 3 205 °C (401 °F) 140 °C (284 °F)
DOT 4 230 °C (446 °F) 155 °C (311 °F)
DOT 5 260 °C (500 °F) 180 °C (356 °F)
DOT 5.1 270 °C (518 °F) 190 °C (374 °F)
Old 10-17-2011, 07:49 PM
Re: brake flush
Blue: http://www.tirerack.com/brakes/acces...tail.jsp?ID=21
Yellow: http://www.tirerack.com/brakes/acces...tail.jsp?ID=22
I got it from here. It's good stuff.
Old 10-17-2011, 09:13 PM
sabin sabin is offline
Banned
Re: brake flush
i used ate in all the track cars i built, never had someone boil it
Old 10-17-2011, 10:07 PM
Re: brake flush
Learned about this stuff from newsvx. he used to run his 97 SVX at Summit Point and VIR.
He has been known to wear out a brand new set of brake pads in one day. Tech inspection requires brake fluid be less than 6 months old, but is probably flushed more often than that.
Harry swears by this stuff. Now using it in his 92 pearlie for autocrossing and other track events.
I still flush mine yearly. I never approach the boiling point, but even the best stuff is hygroscopic (absorbs moisture).
