Old 08-29-2011, 08:37 PM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
How do you remove coil connector ends Driver's side
On the driver's side, I am having trouble figuring out how to remove the plastic electrical connectors green, white, blue, from the metal bracket. I have unplugged them and pulled the coils out from the block, but those damn plastic things are a nuisance. I had to keep the coolant hoses on because coolant kept flowing when I removed the one hose. Problem is the connectors are under the two coolant hoses.
PS I have removed the coil #6 without going through the fender, it was quite easy actually.
1995 Subaru Svx L / AWD
Old 08-29-2011, 09:10 PM
Re: How do you remove coil connector ends Driver's side
The "diving board has to be pushed to the rear.
Or,
the release lever/blade must be pushed toward the firewall.
It all makes sence after you are done.
Old 08-30-2011, 04:55 AM
msvx95's Avatar
It's just a phase
Ok thanks, I will try that tonite. I was pushing towards the coolant reservoir.
Old 08-30-2011, 06:23 AM
Take a close look at your replacement coil connector.
Old 08-30-2011, 07:55 PM
msvx95's Avatar
It's just a phase
Well just as I thought it didn't remove towards the firewall, but towards the coolant reservoir...I still had to hit them with a mallet and screwdriver to get them off. Coils are off and plugs are out..just waiting for my fedex shipment on new coils and plugs.
