Old 08-15-2011, 10:24 PM
Green1995SVX's Avatar
Re: Oil pressure light acting funny
Originally Posted by LastSVXintheChi View Post
Oh **** idk...i had it done at firestne and they dont ussually use new parts they go the cheap route so mostly remain parts and it was only like 80 bucks to have it done...so probabky not
Did these symptoms start shortly after they replaced the switch?
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 08-16-2011, 08:21 AM
LastSVXintheChi's Avatar
LastSVXintheChi LastSVXintheChi is offline
Send a message via AIM to LastSVXintheChi
Not that I noticed...i didnt notice it until a couple months ago
Jared
1992 dark teal SVX LS
Old 08-16-2011, 08:55 AM
I would remove the oil pump and replace it... i have seen backing plate screws back out and result in spun bearings. Also seen pressure relief valves hang up causing low oil pressure... this is all hinged on the fact that pressure is actually low. Get a suby dealer to hook up a manual gauge to confirm
Old 08-16-2011, 09:36 AM
tom
do you know about how much that it? i it but i couldnt find anything on subaru...there was one for a 3000gt they were saying about $700
thanks
Jared
Old 08-16-2011, 10:53 AM
I forget but it is labor intensive due to location. Have the oil pressure checked first to make sure it is actually low.
Old 08-16-2011, 11:19 AM
ok...thanks Tom!
Jared
Old 08-21-2011, 10:43 AM
I havent had a chance to have the oil pressure checked but the light hasnt come on in the 3 days and i havent changed anything....im starting to think its some kind of electrical glitch.....
Jared
Old 08-21-2011, 12:45 PM
If u want to wager ur engine on it....
Old 08-21-2011, 01:11 PM
Tapani Tapani is offline
If the oile gets diluted with fuel (for one reason or another) the viscosity will be low and this could be the result.... Happened to me on a Range Rover once...... it was a carbed engine and the reason was just moving the car on a lot with the choke on and a VERY rich idle.
Just a thought, but would be evident if you check the actual pressure with a simple mechanical gauge.
Tapani
Old 08-21-2011, 04:50 PM
Nate, (to a degree)
dcb,
Tony,
Harvey,
Matt,
YT,
And Mike are ALL correct in their statements.
Subaru does have low pressure at idle,
the oil pumps need to be removed and the screws retightened every now and then,
USE ONLY SUBARU PRESSURE SENSORS!
Old 08-21-2011, 04:52 PM
Tapani also brings up a good point, but if your oil gets that contaminated the engine usually seizes about the time the light comes on.
Old 08-21-2011, 06:13 PM
Tom: if the oil pressure was off would I feel more pressure on the engine when the light goes on or even if it didnt go on?
Also anyone, I have a pretty bad oil leak that seems to be at the front passanger side of the engine...is this where theoil pressure sensor or switch or whatever it is called is?
Jared
Old 08-21-2011, 09:01 PM
Tom:
I am not sure that I understand your question.
please explain/expand.
Old 08-22-2011, 09:29 AM
if the oil pressure was low wouldn't i hear a knock from the engine or wouldn't i feel more strain on the engine?
[/QUOTE]Also anyone, I have a pretty bad oil leak that seems to be at the front passanger side of the engine...is this where the oil pressure sensor or switch or whatever it is called is? [/QUOTE]
i asked this cus i dont know if this would have any effect...
Jared
Old 08-22-2011, 10:32 AM
i asked this cus i dont know if this would have any effect...[/QUOTE]
You would not hear the knock from the engine untill the bearings were worn out.
There would not be a power loss untill the bearings started to gaul.
